Hi,
I've been using this program with great results.
I use MOTV ver 2.1.8 with the latest Nero software, a Nec 3500A DVD burner, with DVD-R discs.
Yesterday I encountered the following problem:
I created a new project, which includes several albums.
Each album includes one large AVI file, which was created by merging several smaller AVI files.
The last album contains photos and music files.
I created a custom menu.
I previewed the disc and everything seemed fine.
Then I selected Burn, with the option "generate new video and burn into Disc", using Nero drivers.
I received a warning that not all the contents might fit into a single disc, and pressed "continue" (This is not the 1st time I receive this message, and until now it has not been a problem).
After about 66% of the creation process has been completed, I received the following message: "please insert cdr or just click ok if you are using the image recorder". If I press OK, the disc is ejected. If I insert the disc again or a cd-r disc), the same process is repeated.
I'd appreciate help.
Results 1 to 1 of 1
BD-R (Ver. 1.1 1L), BD-RE (Ver. 2.1 1L) discs
By mobie29 in forum Authoring (Blu-ray)Replies: 2Last Post: 13th Jun 2010, 14:57 -
DVD memories - the early days!
By lordsmurf in forum MediaReplies: 5Last Post: 14th Jan 2009, 22:06 -
Memories on TV Pro v4 Problem
By davequa in forum Newbie / General discussionsReplies: 2Last Post: 9th Oct 2008, 21:00 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
Photodex ProShow Gold or Memories on TV for DVD Slideshow
By jet757f in forum Newbie / General discussionsReplies: 13Last Post: 8th Nov 2007, 12:44
