I have a PAL AVI with 128 Kb/s stereo that I want to convert to play on my standalone NTSC DVD player that does not play DIVX.
I have successfully extracted, converted and played a 5 minute test using 448 kb/s as the bitrate for the audio.
My question is when converting the audio from WAV to AC3 using ffmpeggui should I be using the 448 or a lower value as the output bitrate?
Thank you in advance.
As long as you have room for an audio file at 448K, it should be fine. That'll work for .AC3, but for some reason I recall you shouldn't go past 384K for MP2.
The ultimate test is to encode it at that rate and try it on your player. -
224 should be OK for AC3 stereo, IMHO.
"Art is making something out of nothing and selling it." - Frank Zappa -
Originally Posted by Soopafresh
Hello,
I've done captures on my hauppauge wintv pvr 250 at 256 mp2 and it sounds just fine. Don't upcode it too much. You won't gain anything out of it and you'll actually take up more space that way too...
Originally Posted by allanc448"Art is making something out of nothing and selling it." - Frank Zappa
Use 192 (the default in FFmpeggui) in either Ac3 or mp2.....and as a bonus this setting seems to avoid synch problems (on 99% of all mp3 vbr's) so avoiding the need to convert to .wav first (believe me, I've been there got the T shirt etc etc)...you can always convert to wav then ac3/mp2 AFTER if you have synch probs on the odd 1% that doesnt convert in synch....just test in your AUTHORER before writing and burning.
Should i put average bitrate or max bitrate in 2pass encoding mode?
By tendra in forum Video ConversionReplies: 28Last Post: 11th Nov 2011, 07:38 -
Converting AVI Audio Bitrate
By RayArt in forum Video ConversionReplies: 3Last Post: 13th Sep 2009, 08:33 -
Using mutiple passes with lower bitrate vs single pass with high bitrate on
By jones24 in forum Newbie / General discussionsReplies: 15Last Post: 14th Aug 2009, 18:17 -
Most compatible codec, Lossless bitrate, and max bitrate
By sevenlayercookie in forum Video ConversionReplies: 2Last Post: 6th May 2009, 20:43 -
Low bitrate source to High bitrate target
By sameerdhiman in forum Newbie / General discussionsReplies: 2Last Post: 7th Nov 2008, 23:54
