    Dec 2004
    . i have 2 avi clips that i want to put onto dvdr, i have used a tutorial using dvd shrink wich was a waste of time as all it has done is joined the two clips together . i want to be able to insert the dvdr with the two clips on and select iether 1 one of them to watch . not watch 1 clip to get to the second .
    anyway to do what i want anyone ?
    heres the tutorial i used
    http://www.dvd-guides.com/content/view/46/59/
    forgot to mentionm the avi clips where converted to dvd files using winavi 1st
  2. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    The output of winavi is DVD ready files, yes? By that I mean a VIDEO_TS folder containing bup, ifo and vob files.
    If so, how large is each dvd that you created? About 2 GB I hope or you won't fit two on a DVD.
    TMPGEnc DVD Author will accept your two dvd's (use the add dvd video button) and will create a menu and burn it to disk. 30 day trial available.
  3. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Either that or convert the AVI files to MPEG-2 using http://members.dodo.net.au/~jimmalenko/AVI2DVD.htm (or any of the conversion guides in the guides section) and then into TMPGEnc DVD AUthor or similar authoring program. The benefit of re-encoding is that you can specify a custom bitrate to ensure that both files will fit on the 1 DVDR.
    If in doubt, Google it.
    Dec 2004
    cheers thanks for the info wil try em both see wich i like thanks
    Jan 2005
    I just used Virtualdubmod and ripped the audio to wav then used TMPGEnc Plus and used the wizard to control the file sizes then demuxed the mpeg2 to m2v and mpa and now im using dvdlab pro to finish the job
    Seedin and encoding... Healthy pc life :)
