I am having problems playing an audio CD I created (using a standard CD-R) in a standalone CD player. When I play store bought CD's with the CD-DA logo they play fine. The manual for the CD player says "This unit is designed to play only compact discs bearing the identification logo as shown here. Other discs may not conform to the CD standard and not play properly." The logo shown is the Compact Disc Digital Audio logo below. My question is, can I buy CD-R's specifically designed to play audio in CD players that would have this CD-DA logo?
Yes they make what is called Audio CD-R’s that are supposed to be more compatible with audio CD players. You will pay more for them because there is a copyright royalty added to them. But in all realty I have never had any problems using standard data CD’s. Your issue is more likely your CD players ability to read burned CD-R’s. How old is your player?
Deek -
The CD player is actually my daughter's and is not that old. It is a Disney Boom Box. We bought it last year.
I have seen the same thing its all "BS". just like those CDr that say these are made for Picture's....again BS!Originally Posted by Deekkeed
Canadateck
You are right it’s BS, although the Audio CD’s were originally made for the Home stereo CD recorders. Most would refuse to record on anything but “made for audio CD’s” they read a code on the disc and if it was not there they would not record. But those days are long past, and all new equipment will burn and read standard CD-R’s. Now it’s just a way for the record company’s to suck some extra dollars out of consumers.
Brergo
From what little info I can find on the Disney boom box. It seems that a lot of people have trouble with it reading anything very good. So I would assume it has relatively cheap components in it. So it may be real picky on what it can read. I would try using a different brand of media and also try burning at the slowest speed your burner can.
deek -
I was thinking of trying another brand of media. I will also try burning at the slowest speed. Thanks.
Realplayer files to another file format or dvd format
By vieya in forum Video ConversionReplies: 8Last Post: 25th Dec 2009, 12:12 -
Converting raw DV format into a quicktime or MPEG format
By Maiden in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 80Last Post: 27th Apr 2009, 20:00 -
Converting from Flash .flv format to iPod Compatible .mp4 format in ffmpegX
By bananasontoast in forum ffmpegX general discussionReplies: 1Last Post: 3rd Jan 2009, 09:15 -
Converting from DVD format to playable on MAC format...
By livvyramone in forum MacReplies: 2Last Post: 23rd Jul 2008, 08:21 -
Convert Coreldraw file format(cpt) to some other format like tiff
By mysts in forum Off topicReplies: 0Last Post: 31st May 2007, 10:38
