Howdy All,
Not a rocket science question I'm sure, but but the icon text on my desktop are all highlighted. I'd just like to have the text below the icon without the highlighting. Can't seem to find where to get rid of it???????? I've already tried:
start/controlpanel/system/advanced/performance/settings/adjust for best appearance with no change so any other angles??
Here's a pic of what I mean. All the desktop icons have a square highlighted background on the text.
Cheers,
Darren
It's probably just a matter of just changing your background color.
Nothing can stop me now, 'cause I don't care anymore. -
I've tried right click/properties/desktop and cant find anywhere to disable or not highlight the icons. I can only change the color and they still show up like this regardless of what color is chosen
Try changing the color of the text.... I think that's a automatic. If the text color falls within a certain pixel range of your background you won't see it so windows automatically highlights it for you.
Okay, just FYI I stumbled across the fix. Right click on desktop/properties/desktop/customize/Web and deleted out the etries in the web pane......lol Learn something new every day
Cheers,
Darren -
Try the 'Let Window$ Choose...' option where you were earlier. The other option would be changing the background color to Black on the Desktop Tab of Display Properties.
EDIT: Glad you got it worked out.Nothing can stop me now, 'cause I don't care anymore. -
Here's the way I fix it.
Right click "My Computer"
Click "Properties"
Click "Advanced" Tab
Click "Settings" in the Performance window
Under the Visuall effects tab click Custom box
then Check the "Use drop shadows for icon labels on the desktop
That works for me
That's only if you set it to "Best Performance"
fuzzy text/desktop display with Sony Bravia TV
By Bacillus98 in forum Media Center PC / MediaCentersReplies: 12Last Post: 24th Feb 2016, 12:29 -
Windows 7 desktop icons
By dfisher052 in forum ComputerReplies: 3Last Post: 30th Mar 2011, 10:55 -
How to restore desktop shortcut arrows and folder/file icons.
By lelouch283 in forum ComputerReplies: 1Last Post: 6th Sep 2010, 22:24 -
windows 7 has shadowed text on desktop
By mysts in forum ComputerReplies: 2Last Post: 16th Oct 2009, 14:37 -
Desktop icons constantly rewriting
By cal_tony in forum ComputerReplies: 8Last Post: 23rd Apr 2008, 16:34
