hi. i have an ISO file copied from a DVD and this is a bike training session. since i don't have a portable dvd player to bring to the garage or a notebook i was thinking of extracting the audio to an MP3 format si that i could play it with my mp3 player. is this possible? how can i extract it? thanks.
Percy
If in doubt, Google it.
wow!
so from all those guides, how can i extract the audio only? thanks.Percy -
Originally Posted by percyv143Then load VIDEO_TS folder into smartripper, and use stream processing mode to demux the audio. Then use besweet to convert to MP3.Extract and Convert
Extract IMG,ISO,BIN/CUE to files with Isobuster or use Daemon tools to mount the image as a virtual CD or DVD drive.If in doubt, Google it. -
1.Mount the ISO with daemontools.
2.Use DVD Audio Extractor to convert to MP3. -
i got the audio extracted from the dvd using the daemon and dvd auio extractor. thanks.
Percy
MP4 audio extraction (ripping the 5.1)?
By takearushfan in forum AudioReplies: 15Last Post: 13th Sep 2010, 09:12 -
Audio extraction from DVD using VirtualDubMod
By Ogilvy in forum AudioReplies: 4Last Post: 29th Mar 2010, 16:56 -
MP4 Audio Extraction
By neumannu47 in forum Video ConversionReplies: 2Last Post: 28th Aug 2008, 20:17 -
capturing audio on PC to MP3 or WAV format, which software ?
By ktnwin in forum AudioReplies: 3Last Post: 2nd Nov 2007, 05:13 -
5.1 audio channel extraction
By efiste2 in forum AudioReplies: 3Last Post: 15th Sep 2007, 05:05
