I'm trying to convert few VHS to DVD using power producer 2Gold.For some reason my 1st try (under HQ) didn't work right. DVD quality littlebit dark, color issues(purple, something close to that.lol) on the top part of the movie ,but not all the time.I just need help choosing the right settings.
one more question.is there another program ez to use like power producer 2Gold(free) ?
1-DISC TYPE DVD
2-VIDEO QUALITY.HQ,SP,or LP?
3-TV STANDARD.NTSC-M, NTSC M J,or NTSC 433 ?
VCR Emerson 4head.
I know my PC needs a major update just waitting for the income tax check biggrin.gif
Results 1 to 15 of 15
Is this a commercial VHS? It sounds like you may be seeing macrovision copy protection kicking in.
nope .all 4 are wedding tapes .its like bluish/purplish blinking light at the upper hand corner
MJA,
Please don't put all your computer specs in your signature. They are already in your Computer specs on your profile page. Anyone can view them by hovering their mouse over the Computer button at the top of every post. Thanks.
As for your problem, it sounds like you have a damaged tape if the color is only appearing in the upper corners. Have you tried adjusting the tracking already? Try the tape on another VCR if you can ..some are more tolerant of this depending on the mechanical slop in the mechanism. -
"As for your problem, it sounds like you have a damaged tape if the color is only appearing in the upper corners. Have you tried adjusting the tracking already? Try the tape on another VCR if you can ..some are more tolerant of this depending on the mechanical slop in the mechanism."
sorry about the signature thing
I'm new here .
About the tapes: The picture looks fine when I watch it on TV, also the VCR doesn't have a tracker. I will see if I can pickup one from Wal-Mart with S-connection. I think they have SANYO 7100 MODEL and /or Panasonic 4750.I’m not sure if both are the correct model numbers -
[quote="MJA"][quote="canadateck"]
Originally Posted by MJA
Do you know of any program similar to Power producer2 Gold(all in one)? -
That sounds like a false MV detection.... some capture cards will falsely detect home movies as being copy protected. Have you captured other tapes sucessfully with it? and if so what is there condition compared to the ones you have now. If you haven't treied any other tapes give it whirl and see what happens.... If you have a very recent 1st generation analog tape (either vhs or hi- 8 ) see if it works with that. If it does....well
See this:
https://www.videohelp.com/forum/viewtopic.php?t=246129
And this:
www.nepadigital.com/mv -
You might be able to get away with using a video "stabilizer", which is not a TBC but an inexpensive way to regulate the sync pulse signal to a stanardized level. Sima makes them (Copy This!) as well as several other companies. Might be worth a try.
Come to the darkside......
Try the Sima products.
" hecoalman
PostPosted: Jan 09, 2005 21:58
That sounds like a false MV detection.... some capture cards will falsely detect home movies as being copy protected. Have you captured other tapes sucessfully with it? and if so what is there condition compared to the ones you have now. If you haven't treied any other tapes give it whirl and see what happens.... If you have a very recent 1st generation analog tape (either vhs or hi- 8 ) see if it works with that. If it does....well "
Thanks for the help. I tried to capture from the VHS copy. Looks a lot better than capturing it from the original copy, but the problem I have now the file is over 8gb. How can I make it an ISO image? Power Producer isn't helping at all. It just made a lot of files.(Default.c00 to Default.c07) -
I stole that from LSOriginally Posted by gshelley61
That is not what I meant, if it works so be it but copies of the original are not going to be as good as the original. I meant to try another tape that was original, preferably a recent one. The reason I suggest this is because the MV probably won't rear it's ugly head if in fact that is the issue your having.Originally Posted by MJA
I'm unfamiliar with that software so I can't really give you an advice about it.
How to convert a PAL VHS into NTSC VHS or DVD?
By coody in forum Video ConversionReplies: 9Last Post: 22nd May 2011, 03:09 -
VHS to DVD - LongPlay VHS Problem
By zanzi81 in forum Capturing and VCRReplies: 14Last Post: 1st Feb 2010, 02:56 -
From DV camcorder to DVD with Nero. helpppp
By kscott0986 in forum Newbie / General discussionsReplies: 5Last Post: 19th Dec 2009, 10:17 -
VHS Copy Protection when using a Dual DVD\VHS Unit
By wizer in forum Capturing and VCRReplies: 1Last Post: 20th Sep 2009, 15:25 -
NTSC VHS to PAL DVD Via DVD VHS Combi
By wozmac in forum DVD & Blu-ray RecordersReplies: 7Last Post: 6th Jun 2007, 02:16
