im in canada...
gota cam corder..just recorded some video...of course its in NTSC format.
is it possible/easy to convert that vhs tape to PAL???, for a friend in OZ.
OR
get the video from cam corder and put it on my PC, do i just plug it in my video card? do i need any software? etc...
Hi ginneypig,
Q1: Check with your friend in Oz to see if his equipment (player and TV) will play NTSC. When I lived in the UK (also PAL) it was common for our equipment (Europe) to play NTSC as well as PAL.
Q2: Is it a DV cam? If so, if it's not too old it will have a firewire out port. Hook this up to a firewire port on your PC and capture to DV AVI using WinDV.
From there, you have many options: VCD, SVCD, DVD etc. There are other possibilities too...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room.
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 12:33 -
How to convert a PAL VHS into NTSC VHS or DVD?
By coody in forum Video ConversionReplies: 9Last Post: 22nd May 2011, 03:09 -
How to watch PAL VHS on NTSC tv
By wolfhunter in forum Video ConversionReplies: 5Last Post: 21st Feb 2011, 15:36 -
VCR is NTSC, but VHS is PAL
By joelson in forum MediaReplies: 1Last Post: 2nd Jun 2009, 09:21 -
Pal S-VHS to NTSC PC
By Jerry1964 in forum Capturing and VCRReplies: 14Last Post: 19th Aug 2008, 09:50
