I'm waiting for a VCR to arrive that will replace my old one that died. I'm wondering how many hours of VHS you can get on a disc without losing the original quality.
Results 1 to 19 of 19
Originally Posted by sync
Are you encoding to Divx, VCD, SVCD, DVD?
D1 or half-D1 resolution?
There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
I figured it would be obvious in the 'DVD Recorder' section - DVD discs. I have a Pioneer 220S. I'm not sure how it handle resolution.
Update your "Computer Information" in your profile - there's a field for entering what DVD recorder you have...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
Depends on the resolution.
Those of us who capture to PC and encode rekon 3000kbps at half D1 is sufficient for VHS to DVD encoding.
That works out at 3 hours of VHS content per DVDR.Regards,
Rob -
1.There is nothing like a “lossless” conversion. The point is how much of it you are willing to accept.
2. The quality of the conversion will depend on the quality of the VHS tape, the quality of the DVD recorder, as well as the quality of the monitor (TV set) that you are using to watch the recordings.
3. If you want to have your tapes converted to DVD’s with the minimal (undetectable) loss of quality then you have to use the 1 Hr mode. If you do it that way you will never loose sleep thinking of how much quality was compromised.
4. Because the 1Hr mode is not very practical, you will probably have to move to the 2Hr recording mode. The quality will be excellent (just a notch below the 1Hr mode) for capturing VHS tapes and therefore it will make you very happy.
5. Everything over 2 Hr will be a challenging for any DVD recorder. -
Good quality from VHS SP mode = 2hr DVD
Compromised quality = 4hr DVD
noisy sources like EP VHS will challenge MPeg2 encoders even more.. -
Some recorders have a 3 hour mode that I understand can be pretty good quality, but it depends on the brand.
"Art is making something out of nothing and selling it." - Frank Zappa -
My recorder has 32 different speeds.
I just did some testing and found that the 3 hour mode records at 352x480. -
The Pioneer has 32 different settings for how much you can record on a disc. The operating manual has a table that shows certain points "where there is a noticeable change in picture quality." You'll notice those points are different depending on if you are recording in VR mode or Video mode. In general, I recommend recording your Video mode DVDs in the 140-minute or shorter group for best quality.
You might want to do a test DVD-RW in VR mode where you record the same content at a variety of manual settings to see where the picture quality becomes unacceptable to you. -
Usually just about 3 hours of live action materials, sometimes up to 4 hours. Cartoons always can go up to 4 hours.
BUT A LOT OF THIS DEPENDS ON THE CAPTURE CARDS, SOFTWARE ENCODERS OR THE DVD RECORDERS.
Inferior equipment will look like crap.
JVC (up to 4), Pioneer (up to 4), Sanyo (up to 3), and hacked LiteOn's (up to 3, sometimes 4) are the only recorders I've really seen that look top-notch at 3-4 hour settings. Most recorders, as was posted in the "Panasonic tips" sticky, should be BANNED from using anything past 2-2˝ hours because it looks like crap (macroblocks, etc).
MPEG capture cards like ATI AIW and Hauppauge are really the only good options here too (within normal budgets).
Most mainstream encoders will also do fine: TMPGEnc, Procoder, MainConcept, maybe CCE, etc.Want my help? Ask here! (not via PM!)
Since VHS is a low resolution source, should 4 hours at half resolution give similar results to 2 hours at full resolution?
When the vcr arrives I'll do my own tests. But I would also like to understand this from a theoretical perspective. -
Quality is in the eye of the beholder. (Sorry for that.)
MN19- MN32* is 720x480 @ +/- 6.0Mbps.
MN7 - MN18 is 352x480 @ +/- 3.0Mbps.
MN1 - MN6 is 352x240 @ +/- 2.0Mbps.
IMO, use MN19 - MN31 for highest quality. (140min. - 65min.)
Use MN7 - MN18 sparingly. (270min. - 150min.)
Use MN1 - MN6 if you really don't care. (360min. - 285min.)
NOTE*:If you you use MN32, you'll get LCPM audio instead of AC3 audio. However, I understand the bit rate on the video goes down a little (compared to MN31). I haven't varified that, though. You can do your own test recording, then press the DISPLAY button (on the remote) during playback to check the bit rates. -
You might want to do a test DVD-RW in VR mode where you record the same content at a variety of manual settings to see where the picture quality becomes unacceptable to you.Quality is in the eye of the beholder. (Sorry for that.)
Sometimes I want to transfer something off the HDD and later put it back on... I'd prefer to avoid multiple re-encodes every time I do that, if it's possible, since it seems like that would reduce quality.
Does this all mean that:
1) if I have a recording at MN21 (120 min) for which the resolution is the same for both VR mode and Video mode, I can get essentially a lossless data transfer from the HDD to a DVD regardless of whether I am in video or VR mode?
2) but if I am at MN19 (140min mode), there will have to be some sort of re-encode if I transfer it to a DVD in VR mode, but I'm OK in Video mode?
Or is there always a loss no matter what?
Thanks in advance for any clarity anyone can bring to this...
nm -
VR usually has more resolutions. VR allows 544x480, 480x480 and a couple others. Not DVD-Video compliant, however, so don't plan to watch these on another player anytime soon.
In practice, no. At least not often.
Read my earlier post. A bit more insight into "why" is put there.Want my help? Ask here! (not via PM!)
Best format to use to maintain video quality?
By Blackhawk1 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 10Last Post: 2nd Apr 2013, 01:17 -
How we maintain original vido quality of vhs while we create dvd from it
By nusratjaveid in forum Capturing and VCRReplies: 5Last Post: 11th May 2011, 21:52 -
Can't compress and maintain quality. Why not?
By justaguy23 in forum Video ConversionReplies: 7Last Post: 10th Jun 2010, 01:55 -
HFS10 - AVCHD how to maintain quality?
By Machoman in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 30Last Post: 18th Jun 2009, 11:57 -
How do you lower bitrate but maintain quality?
By zanos in forum Video ConversionReplies: 7Last Post: 11th Dec 2008, 00:43
