  1. hi.. i was trying burn to DVD using my SONY DVD RW DRU-710A, and i got this burn failure. i save the log files. any1 can help me what is goin on?? oh and i just update the firmware, thnx...
    Windows XP 5.1
    IA32
    WinAspi: File 'Wnaspi32.dll': Ver=4.71 (0001), size=45056 bytes, created 06/05/2002 10:01:14 AM
    ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.68, size=160016 bytes, created 22/07/2004 5:33:44 PM
    Nero version: 6.3.1.25
    Recorder:             <SONY DVD RW DRU-710A>    Version: BYX2 - HA 1 TA 0 - 6.3.1.25
     Adapter driver:      <atapi>                   HA 1
     Drive buffer  :      2048kB
     Bus Type      :      default (0) -> ATAPI, detected: ATAPI
    CD-ROM:               <AXV      CD/DVD-ROM      >Version: 2.2a - HA 2 TA 0 - 6.3.1.25
     Adapter driver:      <a347scsi>                HA 2
    === Scsi-Device-Map ===
    DiskPeripheral       : ST380021A                        atapi Port 0 ID 0  DMA: On
    DiskPeripheral       : WDC WD1200JB-32EVA0              atapi Port 0 ID 1  DMA: On
    CdRomPeripheral      : SONY DVD RW DRU-710A             atapi Port 1 ID 0  DMA: On
    CdRomPeripheral      : HL-DT-ST CD-RW GCE-8523B         atapi Port 1 ID 1  DMA: On
    CdRomPeripheral      : AXV     CD/DVD-ROM      2.2a  a347scsi Port 2 ID 0  DMA: Off
    CdRomPeripheral      : OBVIOUS DVD-ROM MAGIC 626.00   obvious Port 3 ID 0  DMA: Off
    === CDRom-Device-Map ===
    SONY DVD RW DRU-710A       H:   CDRom5
    HL-DT-ST CD-RW GCE-8523B   I:   CDRom1
    AXV CD/DVD-ROM             K:   CDRom2
    OBVIOUS DVD-ROM MAGIC 62   J:   CDRom3
    AutoRun : 1
    Excluded drive IDs:
    WriteBufferSize: 83886080 (0) Byte
    ShowDrvBufStat : 0
    BUFE           : 0
    Physical memory     : 1022MB (1047276kB)
    Free physical memory: 532MB (545724kB)
    Memory in use       : 47 %
    Uncached PFiles: 0x0
    Use Static Write Speed Table: 0
    Use Inquiry    : 1
    Global Bus Type: default (0)
    Check supported media : Disabled (0)
    9.1.2005
    ISO compilation
    3:08:19 PM	#1 Text 0 File Isodoc.cpp, Line 6083
    	Iso document burn settings
    	Determine maximum speed : FALSE
    	Simulate                : FALSE
    	Write                   : TRUE
    	Finalize CD             : FALSE
    	Multisession            : TRUE
    	Multisession type:      : Start multisession
    	Burning mode            : DAO
    	Mode                    : 1
    	ISO Level               : 1 (Max. of 11 = 8 + 3 char)
    	Character set           : ISO 9660
    	Joliet                  : TRUE
    	Allow pathdepth more than 8 directories : TRUE
    	Allow more than 255 characters in path  : TRUE
    	Write ISO9660 ;1 file extensions        : TRUE
    3:08:19 PM	#2 Text 0 File Reader.cpp, Line 126
    	Reader running
    3:08:19 PM	#3 Text 0 File Writer.cpp, Line 124
    	Writer SONY     DVD RW DRU-710A  running
    3:08:19 PM	#4 ISO9660GEN -11 File geniso.cpp, Line 3899
    	First writeable address = 0 (0x00000000)
    3:08:19 PM	#5 Text 0 File Burncd.cpp, Line 3152
    	Turn on Disc-at-once, using DVD media
    3:08:19 PM	#6 Text 0 File DlgWaitCD.cpp, Line 247
    	Last possible write address on media:  2298495 (510:46.45, 4489MB)
    	Last address to be written:            1795903 (399:05.28, 3507MB)
    3:08:19 PM	#7 Text 0 File DlgWaitCD.cpp, Line 259
    	Write in overburning mode: NO (enabled: CD)
    3:08:19 PM	#8 Text 0 File DlgWaitCD.cpp, Line 2162
    	Recorder: SONY DVD RW DRU-710A, Media type: DVD-R
    	 Disc Manufacturer: Yi Jha - n 001
    	 Disc Application Code: 64, Disc Physical Code: 193
    3:08:19 PM	#9 Text 0 File DlgWaitCD.cpp, Line 420
    	>>> Protocol of DlgWaitCD activities: <<<
    3:08:19 PM	#10 Text 0 File ThreadedTransferInterface.cpp, Line 813
    	Setup items (after recorder preparation)
    	 0: TRM_DATA_MODE1 (CTransferItem)
    	    2 indices, index0 (150) not provided
    	    original disc pos #0 + 1795904 (1795904) = #1795904/399:5.29
    	    relocatable, disc pos for caching/writing not required/required, no patch infos
    	    -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 1795904 blocks [SONY     DVD RW DRU-710A ]
    3:08:24 PM	#11 Text 0 File ThreadedTransferInterface.cpp, Line 984
    	Prepare recorder [SONY     DVD RW DRU-710A ] for write in CUE-sheet-DAO
    	DAO infos:
    	 MCN: ""
    	 TOCType: 0x00; Session Closed, disc fixated
    	 Tracks 1 to 1:
    	   1: TRM_DATA_MODE1, 2048/0x00, FilePos             0             0    3678011392, ISRC ""
    	DAO layout:
    	 __Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
    	       0 |  lead-in |   0 |   0x00 |  0x41
    	       0 |        1 |   0 |   0x00 |  0x41
    	       0 |        1 |   1 |   0x00 |  0x41
    	 1795904 | lead-out |   1 |   0x00 |  0x41
    3:08:24 PM	#12 Phase 24 File dlgbrnst.cpp, Line 1855
    	Caching of files started
    3:08:24 PM	#13 Text 0 File Burncd.cpp, Line 4163
    	Cache writing successful.
    3:08:24 PM	#14 Phase 25 File dlgbrnst.cpp, Line 1855
    	Caching of files completed
    3:08:24 PM	#15 Phase 36 File dlgbrnst.cpp, Line 1855
    	Burn process started at 4x (5,540 KB/s)
    3:08:24 PM	#16 Text 0 File ThreadedTransferInterface.cpp, Line 2344
    	Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
    3:08:24 PM	#17 Text 0 File dlgbrnst.cpp, Line 1713
    	Set remaining time: 11:13,303 (673303ms) -> OK
    3:08:24 PM	#18 Text 0 File DVDR.cpp, Line 2000
    	Recording mode: Sequential Recording Mode
    3:08:24 PM	#19 Text 0 File Mmc.cpp, Line 20660
    	Set BUFE: Power-Burn -> ON , Generic write control : ON
    3:08:24 PM	#20 Text 0 File DVDR.cpp, Line 2141
    	Start write address at LBA 0
    	DVD high compatibility mode: Yes
    3:08:24 PM	#21 Text 0 File Cdrdrv.cpp, Line 8230
    	---- DVD Structure: Physical Format Information (00h) ----
    	Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
    	 Book Type: DVD-R   (2), Part Version: 5
    	 Disc Size: 120 mm,      Maximum Rate: <not specified> (F h)
    	 Number of Layers: 1,    Track Path: Parallel Track Path (PTP),  Layer Type: recordable
    	 Linear Density:         0,267 um/bit,  Track Density:  0,74 um/track
    	 Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
    	 End Physical Sector Number of Data Area:      0 h
    	 End Sector Number in Layer 0:                 0 h
    	 Data in Burst Cutting Area (BCA) does not exist
    	  Start sector number of the current Border-Out: 0 h
    	  Start sector number of the next Border-In:     0 h
    	 Media Specific [16..63]:
    	      00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00    ................
    3:09:30 PM	#22 Text 0 File Cdrdrv.cpp, Line 1297
    	15:09:30.906 - SONY DVD RW DRU-710A\H1 T0 : Queue again later
    3:20:47 PM	#23 Text 0 File WriterStatus.cpp, Line 115
    	<SONY     DVD RW DRU-710A > start writing Lead-Out at LBA 1795904 (1B6740h), lenght 0 blocks
    3:20:47 PM	#24 Text 0 File ThreadedTransfer.cpp, Line 229
    	all writers idle, stopping conversion
    3:20:47 PM	#25 Text 0 File DVDR.cpp, Line 2383
    	EndDAO: Last written address was 1795903
    3:21:26 PM	#26 SCSI -1194 File Cdrdrv.cpp, Line 1191
    	SCSI Exec, HA 1, TA 0, LUN 0
    	Status:     0x04 (0x01, SCSI_ERR)
    	HA-Status   0x00 (0x00, OK)
    	TA-Status   0x02 (0x01, SCSI_TASTATUS_CHKCOND)
    	Sense Key:  0x03 (KEY_MEDIUM_ERROR)
    	Sense Code: 0x73
    	Sense Qual: 0x04
    	CDB Data:   0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    	Sense Data: 0x71 0x00 0x03 0x00 0x00 0x00 0x00 0x0A
    	            0x00 0x00 0x00 0x00 0x73 0x04
    3:21:26 PM	#27 Text 0 File dlgbrnst.cpp, Line 1713
    	Set remaining time: 0:00,000 (0ms) -> OK
    3:21:26 PM	#28 CDR -1194 File ThreadedTransferInterface.cpp, Line 1708
    	PMA update failure
    3:21:26 PM	#29 TRANSFER -24 File ThreadedTransferInterface.cpp, Line 1708
    	Could not perform end of Disc-at-once
    3:21:26 PM	#30 Text 0 File DVDR.cpp, Line 2383
    	EndDAO: Last written address was -1
    3:21:26 PM	#31 Text 0 File dlgbrnst.cpp, Line 1713
    3:21:26 PM	#32 Text 0 File dlgbrnst.cpp, Line 1713
    3:21:26 PM	#33 Phase 38 File dlgbrnst.cpp, Line 1855
    	Burn process failed at 4x (5,540 KB/s)
    Existing drivers:
    File 'Drivers\ASPI32.SYS': Ver=4.71 (0001), size=17005 bytes, created 06/05/2002 10:01:08 AM
    File 'Drivers\PXHELP20.SYS': Ver=2.02.62a, size=20016 bytes, created 28/10/2003 5:02:00 AM (Prassi/Veritas driver for win 2K)
    File 'Drivers\atapi.sys': Ver=?.?.?.?, size=86912 bytes, created 29/08/2002 12:27:50 AM (Adapter driver for rec)
    File 'Drivers\a347scsi.sys': Ver=3.47.0.0 built by: WinDDK, size=5248 bytes, created 30/04/2004 8:33:00 AM (Adapter driver for src)
  2. Yeah, 95% of the time its the media. Isn't that a Liteon or a Benq writer?
