Is there a way that I can fit a widescreen format MPEG file onto a DVD? Right now, the file is an AVI, and I need to encode it, but it's widescreen right now. It is 576x240, and I don't want to make it 720x480, because it would look too weird. Are there any ways I can make it fit? Thanks!
Widescreen video for DVD is an attribute, the resolution has nothing to do with it. Look up anamorphic in the glossary. Use software that supports widescreen encoding and authoring.
thecoalman is correct. Look at the definative guide: https://www.videohelp.com/guides.php?guideid=360#360 by DJ Rumpy
And then try SVCD2DVD v2.0 which does all the stuff in the guide automatically. http://www.svcd2dvd.com/downloads.aspx#SVCD2DVD2SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Dvd player plays widescreen dvds in fullscreen on widescreen tv
By Fireworks_at_Dawn in forum Newbie / General discussionsReplies: 35Last Post: 24th Sep 2012, 09:24 -
How to fullfill a widescreen video (4:3) into a widescreen project (16:9)?
By coxanhvn in forum Newbie / General discussionsReplies: 8Last Post: 10th May 2011, 12:59 -
Widescreen movie on Widescreen TV with blacks bars???
By overloaded_ide in forum DVB / IPTVReplies: 14Last Post: 11th Dec 2009, 14:22 -
Convert Pseudo Widescreen to Proper Widescreen
By simonw2008 in forum Video ConversionReplies: 5Last Post: 5th Apr 2008, 21:57 -
Convert letterboxed widescreen to anamorphic widescreen?
By ziggy1971 in forum Video ConversionReplies: 6Last Post: 7th Mar 2008, 23:15
