WOW -seems that I have big problems. I purchased both the DVDXCopy and the DVDXCopyXpress from 321studios. They have worked beatifully for me so I even bought a bunch of other softwares.
Now, 321 went belly up and my computer needs a systemreinstall. My problem is obvious, the registration of the software required online registration towards 321studios servers and since they are down, I can not reinstall my software. Ouch, 600 bucks down the tubes or do you know how to solve this?
Please help!
If its all lost -do you know if Jambalayabrands new products DVD Double and Game Clone are any good? Can they do the job?
Sincerely,
Johan
Dump dvdx copy and use dvddecrypter and dvdshrink.
They are both free and easy to use. -
You have a lot to learn
For riping and copying, everything you need is free,I also think the 321 Software was even based on free software , they riped off.I think..
Ok, I get the picture. I am lazy
Now, I did buy these products because they enabled me to make backup copies of my DVDs.
Are you all telling me that DVD decrypter is easy enough to make an image and dvdshrink will bring it to a single side DVD easy enough I will try it. But if it wil be hours and hours of learning then it is not my cup of tea.
Let me know, thanks.
JOhan -
You can also burn DVD decrypter if the main movie or the Whole DVD fits on one DVDr.
Installing KDNLive
By Bonie81 in forum Newbie / General discussionsReplies: 4Last Post: 12th Jul 2011, 20:32 -
Installing XP on a used PC
By CSULB71 in forum ComputerReplies: 24Last Post: 21st Nov 2008, 12:05 -
installing
By lindakay in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 4th Mar 2008, 08:13 -
installing Binaries
By mahanpots in forum ffmpegX general discussionReplies: 1Last Post: 14th Dec 2007, 11:16 -
Installing Aften
By jsm1963 in forum AudioReplies: 2Last Post: 29th Nov 2007, 19:38
