hi all,
i have 2 pc's which have been configured to network with each other but im having trouble for sharing my printer on the second machine . My question is do i have to install the printer software on second pc in order to print?
thanks in advance.
kas
For me it's not necessary.
When I installed my shared printed I didn't select local printer, but printer connected to an other PC. In my case I have XP in both PCs. Take a look to the firewalls programs.Minds are like parachutes. They only function when they are open ! -
It shouldn't necesarily make a difference but, are both computers in the same workgroup? When you setup printer sharing on the machine that's connected to the printer, does it show in the printers folder that it's shared? There should be a hand underneath the printer. If this is the case, are you able to see the connected computer from the networked computer in My Network Places? If so, try sharing a folder temporarily to see if that works. When you get to a certain point in the Add Printer Wizard, it will ask you for drivers if they're not already built into the OS.
Nothing can stop me now, 'cause I don't care anymore.
My HP printer D5360 died, looking for a new DVD printer
By stiltman in forum MediaReplies: 9Last Post: 18th Mar 2011, 23:04 -
OT: Sharing files
By danielmak in forum MacReplies: 3Last Post: 26th Aug 2008, 21:44 -
Sharing Epson Printer
By stiltman in forum ComputerReplies: 0Last Post: 1st May 2008, 23:12 -
Steps For Sharing Printer In Home Network
By rockaway in forum ComputerReplies: 1Last Post: 3rd Apr 2008, 14:50 -
Sharing violation?
By bevills1 in forum ComputerReplies: 2Last Post: 10th Jul 2007, 13:16
