My friend gave me a VHS tape and also a DVD (converted from the same tape) of his wedding and asked me if I could remove some of the background noise. I thought it would be rather simple, but I am having some problems. Using Goldwave I cannot get the filtered sound back into a mpg. file and using TMPGenc I cannot even open the original file.
Can anyone help the village idiot here with this task? I am simply trying to reduce noise from either a dvd or a vhs. Virtual Dub perhaps, and if so how?
Thanks for your help.
Results 1 to 12 of 12
The frontiers of our mind are the last place we find, but maybe the first place we should look.
Thanks for your help. Please forgive my lack of knowledge but I can't even get the first step. How do I get the file into VDub from the DVD in the first place? Do I need to use Decrypter first and convert it to mpeg?Originally Posted by TommyknockerThe frontiers of our mind are the last place we find, but maybe the first place we should look.
No. All the video is contained in VOBs. Virtual Dub can load these VOBs.
Hello. -
That's what a thought but when I go to load them it does not give the option to. If I swicth to show "all files" and try to load the VOB that way it says not supported. ???????? I must be missing something simple.
The frontiers of our mind are the last place we find, but maybe the first place we should look. -
Use DVD Decrypter in IFO mode to "rip" the video and audio. If you set it up correctly you will have a single M2V video file and a single audio file which can be either AC-3, MP2 or LPCM WAV depending on what is on the original DVD.
If you get LPCM WAV then you can load that directly into GOLDWAVE otherwise you can use BeSweet to convert AC-3 or MP2 audio into LPCM WAV which you can then load into GOLDWAVE.
You are better off converting back to AC-3 in the end than MP2 but if the original used LPCM WAV then that you can use that instead. In other words always pick AC-3 over MP2 if you can't use LPCM WAV audio.
- John "FulciLives" Coleman
P.S.
If you do this with DVD Decrypter you will have, as I said, a single large M2V video file. You will need this in the end when you go to your re-authoring stage to put the original video back together with the new audio."The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
I didn't know that was possible.Originally Posted by ZippyP.
I assume you would really only want to do that if it is a 2.0 AC-3 otherwise how would it "handle" a 5.1 AC-3 etc.?
need method for video noise reduction
By codemaster in forum EditingReplies: 2Last Post: 1st Jan 2012, 18:10 -
Speaking of noise reduction, what is this?
By takearushfan in forum RestorationReplies: 11Last Post: 5th May 2010, 22:14 -
Any Suggestions for Noise Reduction Software
By blaqlion22 in forum AudioReplies: 13Last Post: 16th Jun 2009, 08:08 -
Noise reduction
By Geevim in forum RestorationReplies: 3Last Post: 5th Nov 2007, 07:23 -
Video Noise Reduction ----> H E L P
By wxyz in forum DVD RippingReplies: 14Last Post: 21st Jun 2007, 20:22
