Alright, I've got an older tv show with multiple eps on dvd, I don't like the main menu of it so I'd like to redo it my way.. the menu is one from tmpg dvd author.. but I'll put the dvd in my drive, and then create new project > add dvd video and it shows me all the episodes on the dvd so I choose one then it says :
*The video resolution 480x480 cannot be used for a standard DVD.
For a standard DVD you can only use the following resolutions:
352x240 352x480 704x480 720x480 pixels (NTSC format only)
352x288 352x576 704x576 720x576 pixels (PAL format only)
AND
*The video framerate 29.97 fps cannot be used with the resolution 480x480.
This framerate can only be used with the following resolutions:
Results 1 to 11 of 11
only_emo_kidGuest
Tmpgenc dvd author will not accept svcd(480x480),you can use dvdpatcher to trick tda into accepting it as long as your dvd player will play this type of non compliant dvd,otherwise you will have to re-encode to 352x480.
only_emo_kidGuestOriginally Posted by johns0
How many dvd players woln't play this? because my apex ad500w plays it fine... hmmm Thx i'll try that -
Sorry, I pulled that number outta my A$$.Originally Posted by only_emo_kid
https://www.videohelp.com/dvdplayers.php?DVDname=&Search=Search&dvdsvcd=1&country=&orde...Submit2=Search shows that out of 419 DVD players tested for DVD-SVCD compatibility, 360 players support it while 59 don't. This is only based on the user reviews though.If in doubt, Google it. -
I use TMPGenc Express to transcode(?) mpeg-2's for SVCD into the correct format for TMPGenc DVD Author to accept. Yes, it does take some time but the results are accepted by Author without complaint and the DVDs play on all my squirrelly players.
only_emo_kidGuest
i'm afraid of anymore quality loss, because its not the best anyhow comming from VHS
Can't say I've had any noticeable quality loss. I set the 720x480 size and keep the bitrate just above the original. If you're coming from VHS through mpeg-2 at 480x480, you're not going to lose anything more than you've already experienced simply by having source material in VHS.
I don't recall if there's a demo version of Author available but, if so, it's certainly worth a few hours of transcoding to see the results. Click "go" and have a long dinner.
Ciao!
TMPG DVD Author-old version
By Mållgan in forum Authoring (DVD)Replies: 12Last Post: 7th Mar 2010, 17:46 -
tmpg dvd author - pal ntsc setting?
By jin007 in forum Authoring (DVD)Replies: 4Last Post: 19th Aug 2008, 15:39 -
Does Tmpg Divx Author encode or it only author ?
By BlackShadow90 in forum Authoring (DVD)Replies: 3Last Post: 29th Jul 2008, 04:56 -
About the .srt subtle files and the TMPG DVD Author
By ihmcjacky in forum Authoring (DVD)Replies: 2Last Post: 10th Mar 2008, 11:58 -
tmpg dvd author 1.6 help plz
By nwa in forum Authoring (DVD)Replies: 8Last Post: 6th Jul 2007, 19:59
