I have looked around at Google and cant find a MPEG file description editor... I mean that I capture old VHS into MPEG-1/2 and when playing in Windows Media Player or similar player, I would like to see my personal info ... I would like to put the author, description, language, an other tags info in the MPEG file...
But I only found the abcAVI Tag Editor... Well, I think it could resolve my problem but create another one... Why would I capture in AVI format and then convert to MPEG if I can capture in MPEG directly???
I use DVD XPress USB device and have Ulead VideoStudio 7 in CD (never installed)...
Any software (free/shareware or paid one) can serve... the simpliest, the better... it is ONLY to edit the TAG/INFO of the file AFTER recorded, but complex/large softwares may be reported...
Thanks in advance.
FRED
Brazil.
Originally Posted by BJ_M
"This program only works with MPEG2 elementary video-streams. If you've got
a system-stream (e.g. a multiplexed file) demultiplex first." As reported in restream website, I have to create an MPEG2 video stream only...
But I mainly create VCD (MPEG1) system streams...
Thanks anyway... I had never heard about restream before... I will download it for future purposes, if needed...
Any other software?
Fred. -
hexedit
no mater what -- its not going to show author , etc in media player
MKV Tag Editor
By gonwk in forum Newbie / General discussionsReplies: 32Last Post: 24th Jan 2021, 09:39 -
Pinnacle studio 14 tag editor or other software noob
By jamesleewhite in forum EditingReplies: 0Last Post: 23rd Jul 2010, 01:22 -
WMA tag editor / renamer
By olyteddy in forum AudioReplies: 5Last Post: 13th May 2009, 10:37 -
Can Anyone Recommend a Good Audio and Video Tag Editor?
By Nitro89 in forum ComputerReplies: 1Last Post: 23rd May 2008, 02:16 -
Is there a good tag editor like MetaX, except able to do AVI and MOV files?
By VidHunter in forum MacReplies: 0Last Post: 9th Nov 2007, 05:57
