You can use your capture card's input as a source. I've used it many times.
Results 31 to 42 of 42
Yes, I can. But that drives the signal through extra circuitry. Why would I use my capture card's input?
My capture card takes the input and redirects it back to the line-in. Physically. It takes the signal coming from the source, and has a physical wire sticking out the back of it reaching up to my line-in port.
My problem is not getting the source.
I have the signal coming from my GameCube, playing on my speakers, but it's only stereo.
I need to do a LIVE decode (DPL-II expansion to 5.1) of the line-in signal before it passes to my system mixer. -
I do not need to bypass the capture card, I am fully capable of hooking it straight into my line-in.
Which is what I've been saying. -
Yeah, that's what I have been saying too.Originally Posted by Cornucopia
I did try it...
I'm using a Sb Live! with a 5.1 sound system (my gamecube is connected in the line-in jack of the card).
Now, I'm using Graphedit to try to get the output of my soundcard to be filtered by FFDShow (which has a Dolby Prologic II matrix filter, just like AC3Filter), but it always fail!
It tells me that "these filters cannot agree on a connection.", in other words, it can't find compatible types between the input and the output pin (this error comes up wether I connect "ffdshow audio decoder" with the "Default directsound device" or wether I connect my Sound Card with FFDShow. See first image to understand the arrangement of filters).
The first screen grab shows the arrangement I tried to make work.
(the sound card filter comes from the "audio capture sources" category, the "ffdshow audio decoder" comes from the "Directshow filters" category and, finally, the "default directsound device" comes from the "audio renderers" category.)
This graph never worked (it always gives me the error about incompatible pins).
The second screenshot shows one graph that IS working (it's not doing DPLII decoding, but the sound is filtered in real-time, which is half of what is expected
(I used a "echo" filter from the "DMO audio effects" category, the other filters are the same as before)
Now, I'm wondering how I could connect my soundcard to a directshow filter (that directshow filter would be FFDShow)... should I connect an "in-between" filter which would do some sort of modification on the audio type?? What would be this "in-between" filter ?
Any Help is appreciated, thanks!
--Yop83
P.S: I'm using Graphedit private build 011008 (got it from the link earlier in this thread). I'm using the "Connect Intelligent" option to auto-scan possible arrangements... -
this is an alternative :
I use the follow software ; Bidule , circle surround vst plug in, and kx proyect drivers.
make the conection , and you can decode live , in real time, dolby prologic, prologic II or other compatible matrix sound
be sure mute the "Inline" input is off , because this can cause feedback or echo.
It works for me , and I use it with my game cube.
Dolby Pro Logic IIx encoder
By nateo200 in forum MacReplies: 4Last Post: 4th Feb 2012, 13:45 -
Dolby Pro Logic vs Dolby Digital?
By therock003 in forum AudioReplies: 17Last Post: 11th Jun 2011, 19:51 -
No Dolby Pro Logic from AC3Machine
By jonghyunchung in forum AudioReplies: 9Last Post: 28th Jan 2009, 14:35 -
A Few Questions About Dolby Pro Logic
By seven_deuce offsuit in forum AudioReplies: 17Last Post: 29th Apr 2008, 15:08 -
How to downconvert Dolby Digital to Dolby Pro Logic II?
By randyharris in forum ffmpegX general discussionReplies: 0Last Post: 2nd Nov 2007, 16:54
