Newbie question . . .
After days and days of headaches I managed to get svcds to play in my Sony DVP-S535D DVD player. The only problem is that menus are not showing up. I can see the menu when I play the CD on my PC with WinDVD, but not on my DVD player.
I checked the instruction manual to make sure that PBC was enabled, but it still doesn't work. Anybody have any suggestions?
thanks
Chris
What program are you using? I tried nero first and couldn't get anything to play. I used Ulead DVD PictureShow
and it worked flawlessly. I also am using the Sony DVP-S560D.
Cool Mo -
Ok, I played around with xml settings for vcdimager and still had no luck with svcd menus. I tried the same layout using vcd and it worked perfectly.
I guess my options are to use svcds without menus or vcds with menus. . . -
Same problem with SONY DVP-NS900V. No PBC mode for SVCDs.
@Clear_Signal: What does the directory structure of your working SVCD (authored with Ulead DVD Picture Show) look like (directory names and filenames)?
Is Ulead DVD Picture show a complete (S)VCD/DVD authoring tool? Sounds more like a Photo CD tool
My Sony DVD player SONY DVP- NS718 H
By samyer in forum Newbie / General discussionsReplies: 1Last Post: 2nd Feb 2010, 23:56 -
Sony dvp sr-100
By munskin in forum DVD & Blu-ray PlayersReplies: 1Last Post: 19th Aug 2009, 11:04 -
Sony DVP-FX720
By haidee in forum Portable VideoReplies: 0Last Post: 3rd Jan 2009, 08:11 -
Sony DVP-NS601HP ??
By jjfromm in forum DVD & Blu-ray RecordersReplies: 1Last Post: 29th Dec 2008, 12:02 -
HELP !!! Please !! Sony DVP-S7700
By adamsj13 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 14th Oct 2007, 04:04
