Closed Thread
  1. OK here goes...
    Problem
    I've made a 30 second "project" using Windows Movie Maker.
    It is saved as a "WMV" File.
    I used a program called "OSS Video Converter" to convert the "WMV File to an MPEG2 File.
    It did this just fine.
    Then I used my NTI Software to burn it to a Blank DVD-R.
    My problem is when I try to play it on my PC, using Power DVD,
    I get an error message of an "unspecified Format".
    It wont play in either of my Standalone DVD Players either.
    When I put the DVD in to play t on my computer it uses RealPlayer or Window Media Player only.
    So I posed this problem to thier tech support and this was they're anser:
    Answer:
    Dear Customer;
    You have to burn your video on a DVD convert it to avi format. For more help you can ask tech support of the DVD.
    Thanks;
    Tech Support.
    __________________________________________________ _______
    OK so I'm a Newbie.
    When I INITIALLY made this clip in Windows Movie Maker, should I have converted it to an AVI File and THEN converted it into MPEG 2 ?
    I just want this sucker to play on my Standalone DVD player!
    one topic is enough.
    https://www.videohelp.com/forum/viewtopic.php?t=251914&highlight=
    just reply to your old topic to add more information.
