I purchased some printable disc with the inner hub also white and printable. Is there a software upgrade so that my IP3000 can print the inner hub as well?? Thanks.
I had the same problem and couldn't work out how to print on the hub. Thanks to someone on here i now know how to do so and here's how.
When you open the canon software select new. Then in select paper type you select new. You should now have a screen where you can set the inner and outer size. For the discs i use you can set the inner to 21mm and outer to 116mm and then give it a name and the setting will save for you to use when you want. You may need a tape measure or ruler with mm so you can measure your discs to get the right settings.
printable discs in non-print burner
By dblake2 in forum MediaReplies: 3Last Post: 31st May 2008, 14:14 -
looking for silver hub printable DVD media
By PharmBoy in forum MediaReplies: 6Last Post: 30th May 2008, 06:31 -
Glossy hub printable DVD+R
By PharmBoy in forum MediaReplies: 9Last Post: 27th May 2008, 09:06 -
TY R47WPP600SK -- hub printable or not?
By spiffy in forum MediaReplies: 6Last Post: 12th Mar 2008, 22:03 -
Dual Layer hub printable media??
By garstan in forum MediaReplies: 4Last Post: 21st Oct 2007, 15:50
