Hi i have done a fresh install of windows last week and now i cant get svcd to work
this happens every file i try - someone please help me out![]()
Logfile
here are my settingsCode:Starting SVCD2DVD: v1.51.2.0 Begin time: 11:27:25 ******** Ripping BIN images to get mpegs (VCDGear ) VCDGear 1.76 final build 031225 coded by Dracore (vcdgear@hotmail.com) Testing and quality control by MACKerMD Language: English Version: 3.50 - Jan. 1, 2003 Translation by: Dracore ----------------------------------- processing method :: (bin2mpg) .bin src(In) -> D:\movies need listing & burning\yug\a.bin .mpg dest(Out) -> D:\movies need listing & burning\yug\a.mpg ----------------------------------- [a.bin] Detected sector size: 2352 # 0% #searching... Track 1: 833256256 bytes [06:51:39] #searching... 1 track(s). Setting read size to: 2352 Setting write size to: 2324 # Track 1 -> writing... # OK! VCDGear 1.76 final build 031225 coded by Dracore (vcdgear@hotmail.com) Testing and quality control by MACKerMD Language: English Version: 3.50 - Jan. 1, 2003 Translation by: Dracore ----------------------------------- processing method :: (bin2mpg) .bin src(In) -> D:\movies need listing & burning\yug\b.bin .mpg dest(Out) -> D:\movies need listing & burning\yug\b.mpg ----------------------------------- [b.bin] Detected sector size: 2352 # 0% #searching... Track 1: 823414116 bytes [05:55:04] #searching... 1 track(s). Setting read size to: 2352 Setting write size to: 2324 # Track 1 -> writing... # OK! (Total size: 1601MB, Duration: 00:02:08, Rate(MB/Min): 745.01) Analysing File: D:\movies need listing & burning\yug\a.mpg ++ WARN: packet length beyond buffer (pos = 20 + size = 2304 > buflen = 452) -- stream may be truncated or packet length > 2324 bytes! ++ WARN: bad packet at packet #451 (stream byte offset 1048124) -- remaining 452 bytes of stream will be ignored Error getting mpeg details. (probably due to AC-3 audio) System.Xml.XmlException: An error occurred while parsing EntityName. Line 1, position 41. at System.Xml.XmlScanner.ScanNamedEntity() at System.Xml.XmlTextReader.ExpandLiteral(XmlAttributeTokenInfo currToken) at System.Xml.XmlTextReader.SetLiteralValues(XmlAttributeTokenInfo fld) at System.Xml.XmlTextReader.SetAttributeValues() at System.Xml.XmlTextReader.ParseElement() at System.Xml.XmlTextReader.Read() at System.Xml.XmlValidatingReader.ReadWithCollectTextToken() at System.Xml.XmlValidatingReader.Read() at System.Xml.XmlLoader.Load(XmlDocument doc, XmlReader reader, Boolean preserveWhitespace) at System.Xml.XmlDocument.Load(XmlReader reader) at System.Xml.XmlDocument.Load(String filename) at _S_VCD2DVDMPG.210ff09a2516b1a7.b4e369192c57af39(2bc216f3ce925842 a01d771a37e7320b) An error occurred while parsing EntityName. Line 1, position 41. at System.Xml.XmlScanner.ScanNamedEntity() at System.Xml.XmlTextReader.ExpandLiteral(XmlAttributeTokenInfo currToken) at System.Xml.XmlTextReader.SetLiteralValues(XmlAttributeTokenInfo fld) at System.Xml.XmlTextReader.SetAttributeValues() at System.Xml.XmlTextReader.ParseElement() at System.Xml.XmlTextReader.Read() at System.Xml.XmlValidatingReader.ReadWithCollectTextToken() at System.Xml.XmlValidatingReader.Read() at System.Xml.XmlLoader.Load(XmlDocument doc, XmlReader reader, Boolean preserveWhitespace) at System.Xml.XmlDocument.Load(XmlReader reader) at System.Xml.XmlDocument.Load(String filename) at _S_VCD2DVDMPG.210ff09a2516b1a7.b4e369192c57af39(2bc216f3ce925842 a01d771a37e7320b) Analysing File: D:\movies need listing & burning\yug\b.mpg ++ WARN: packet length beyond buffer (pos = 20 + size = 2304 > buflen = 452) -- stream may be truncated or packet length > 2324 bytes! ++ WARN: bad packet at packet #451 (stream byte offset 1048124) -- remaining 452 bytes of stream will be ignored Error getting mpeg details. (probably due to AC-3 audio) System.Xml.XmlException: An error occurred while parsing EntityName. Line 1, position 41. at System.Xml.XmlScanner.ScanNamedEntity() at System.Xml.XmlTextReader.ExpandLiteral(XmlAttributeTokenInfo currToken) at System.Xml.XmlTextReader.SetLiteralValues(XmlAttributeTokenInfo fld) at System.Xml.XmlTextReader.SetAttributeValues() at System.Xml.XmlTextReader.ParseElement() at System.Xml.XmlTextReader.Read() at System.Xml.XmlValidatingReader.ReadWithCollectTextToken() at System.Xml.XmlValidatingReader.Read() at System.Xml.XmlLoader.Load(XmlDocument doc, XmlReader reader, Boolean preserveWhitespace) at System.Xml.XmlDocument.Load(XmlReader reader) at System.Xml.XmlDocument.Load(String filename) at _S_VCD2DVDMPG.210ff09a2516b1a7.b4e369192c57af39(2bc216f3ce925842 a01d771a37e7320b) An error occurred while parsing EntityName. Line 1, position 41. at System.Xml.XmlScanner.ScanNamedEntity() at System.Xml.XmlTextReader.ExpandLiteral(XmlAttributeTokenInfo currToken) at System.Xml.XmlTextReader.SetLiteralValues(XmlAttributeTokenInfo fld) at System.Xml.XmlTextReader.SetAttributeValues() at System.Xml.XmlTextReader.ParseElement() at System.Xml.XmlTextReader.Read() at System.Xml.XmlValidatingReader.ReadWithCollectTextToken() at System.Xml.XmlValidatingReader.Read() at System.Xml.XmlLoader.Load(XmlDocument doc, XmlReader reader, Boolean preserveWhitespace) at System.Xml.XmlDocument.Load(XmlReader reader) at System.Xml.XmlDocument.Load(String filename) at _S_VCD2DVDMPG.210ff09a2516b1a7.b4e369192c57af39(2bc216f3ce925842 a01d771a37e7320b) -->Processing 2 mpeg files ############### New MPEG File ############### File: D:\movies need listing & burning\yug\a.mpg Type: VCD Horizontal Res: 0 Standard: PAL Audio SampleRate: 0 ******** Demultipexing original mpg file (Total size: 794MB, Duration: 00:01:58, Rate(MB/Min): 401.07) ******** Resampling audio from 44.1 KHz to 48 KHz (Total size: 73MB, Duration: 00:01:04, Rate(MB/Min): 67.47) ******** Trimming start of video ES System.IO.FileNotFoundException: Could not find file "D:\movies need listing & burning\yug\a_DVD.mpv". File name: "D:\movies need listing & burning\yug\a_DVD.mpv" at System.IO.__Error.WinIOError(Int32 errorCode, String str) at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, Boolean useAsync, String msgPath, Boolean bFromProxy) at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize) at System.IO.StreamReader..ctor(String path, Encoding encoding, Boolean detectEncodingFromByteOrderMarks, Int32 bufferSize) at System.IO.StreamReader..ctor(String path) at _S_VCD2DVDMPG.210ff09a2516b1a7.54d310f1b21a8a6d(2bc216f3ce925842 a01d771a37e7320b) at _S_VCD2DVDMPG.210ff09a2516b1a7.f5d131c1b9f0edc5() Could not find file "D:\movies need listing & burning\yug\a_DVD.mpv". at System.IO.__Error.WinIOError(Int32 errorCode, String str) at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, Boolean useAsync, String msgPath, Boolean bFromProxy) at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize) at System.IO.StreamReader..ctor(String path, Encoding encoding, Boolean detectEncodingFromByteOrderMarks, Int32 bufferSize) at System.IO.StreamReader..ctor(String path) at _S_VCD2DVDMPG.210ff09a2516b1a7.54d310f1b21a8a6d(2bc216f3ce925842 a01d771a37e7320b) at _S_VCD2DVDMPG.210ff09a2516b1a7.f5d131c1b9f0edc5()
Thanx
should of checked first before posting
sorted thanx - it was the "&" symbol in the working directory
totally new to ripping DVDs
By xland in forum MacReplies: 2Last Post: 25th Jan 2009, 08:05 -
Totally lost with playing HD video on my PC
By jessica82 in forum Newbie / General discussionsReplies: 8Last Post: 1st Jan 2009, 21:53 -
Fraps to iMovie totally impossible !!
By kinkladze10 in forum Video ConversionReplies: 4Last Post: 14th Jul 2008, 06:53 -
Totally new to this? Copy to DVD-R ?
By rami007 in forum Newbie / General discussionsReplies: 9Last Post: 7th Aug 2007, 14:11
