This is a long post, so bear with me.. please.
I had to re-install windows and format my hard-drive to get rid of this evil spyware application called Aureate. I got this computer second hand, so I don't have any drivers on disk for any hardware.
Since i've reinstalled XP, my DVD-Rom (nu 52x24x52x16x DVDR/CD-RW) can not be used to burn on with Nero, it only detects "Image Recorder" as the recording-device and not the CD-RW drive.
Also since ive re-installed, the DVD movie quality is really bad in PowerDVD and WinDVD, the video quality is jumpy and the audio is somewhat choppy. I can remedy this by making the dvd-screen size really small, but that obviously is not a great solution to it.
Are the two problems linked?
If not what could be the solution to each of the problems?
Here are my specs
600mhz 128mb RAM 40gb HDD
Latest DirectX, Nero burning rom 5
Dont tell me to try turning on DMA for my DVD-Rom, as I dont think it has DMA, I certainly can't see it in options.
It could be the following:-
After installing XP, did you install the correct drivers for you motherboard and your graphics card. That would explain poor DVD playback problems.
With NERO, your version might be an OEM version, that works with a particular drive. You might need to install a serial number for Nero to recognise your writer.TOMMO -
"as I dont think it has DMA, I certainly can't see it in options."
Might be your bios doesn't have your drives listed.
How to Install Windows 7 O.S on new Internal Hard disk & make Partition ?
By skorpinok in forum ComputerReplies: 10Last Post: 26th Aug 2011, 06:13 -
CDRW Erasing Cancelled - CDRW NOT WORKing
By Sarao in forum ComputerReplies: 6Last Post: 5th Feb 2010, 10:55 -
ImageMixer3 & MovieAlbum install both?
By zmartha in forum Newbie / General discussionsReplies: 1Last Post: 25th Apr 2009, 22:47 -
Can't install, password problems
By seanK in forum ffmpegX general discussionReplies: 3Last Post: 26th Jun 2008, 02:14 -
Two problems with WinXP re-install
By tweedledee in forum ComputerReplies: 9Last Post: 23rd Jun 2007, 20:38
