I know there's a program that will convert from type one to type two, but is there a program that can convert back to type 1? I only ask this because my video editing software is refusing to take type 2 for some reason. thanx.
Results 1 to 13 of 13
Heres the best I could find for you.
http://msdn.microsoft.com/library/default.asp?url=/library/en-us/directshow/htm/type1v...pe2dvfiles.asp
Check the Canopus DV File Converter. I think it will do a 2->1 conversion (Don't have access to my edit suite right now, so I can't say for sure).
Why in the world would you ever want to convert back to Type 1? Type 2 is so much more convenient to work with. You see all those little programs designed to do Type 1 > Type 2? Well, why do you think they are that way and not Type 2 > Type 1? Stick with Type 2, don't make your life that much harder.
Originally Posted by State Of Mind
Maybe because his software doesn't support Type-2.... Most of the converters are there because Virtualdub only supports type-2. Most major editing programs support either or are compatible with type-1.
BTW The Canopus DV converter does support conversion to type-1. -
If your software doesn't support Type 2 DV, then you need different software!
If you have installed a DV codec (try the Panasonic DV codec), type 2 avi should work with any program. The only difference between type 2 and type 1 is that type 2 extracts the audio from the DV stream to store it separately.
Incidentally, Virtualdub experimental 1.6.2 now reads type 1 DV avi files. -
DVdate (look in the tools section of this website) does the job to convert from type 2 to type 1 as well as the contrary.
https://www.videohelp.com/tools?tool=DVdatePaul Glagla
http://paul.glagla.free.fr/index_en.htm -
I just transfer DV from jvc miniDV camera. The resulting AVI is only 1 file, this means my DV is type 1? If yes how to make type 2 DV from my camcorder?Originally Posted by yg1968
This link explains the Type1/Type2 issue.
It affects how audio is multiplxed. Commercial software usually uses Type2. -
Most software will also accept type 1 DV avi. Vdub experimental 1.6.3
also accepts type 1. I usually capture in type 1. -
some avid software only takes type 1 (oddly enough)
Convert DV type 2 to type 1? Or is there an app that will correct sync?
By Colmino in forum Newbie / General discussionsReplies: 7Last Post: 20th Dec 2022, 22:24 -
How to convert a trp type file to Mpeg2 type?
By Jemes-bs in forum Video ConversionReplies: 2Last Post: 13th Oct 2010, 16:59 -
type 1 or type 2 capture-newbie
By sar in forum Capturing and VCRReplies: 6Last Post: 28th Jul 2008, 19:22 -
DV AVI Type 2 -> Type 1 converter?
By alx3d in forum EditingReplies: 3Last Post: 29th Dec 2007, 21:16 -
Convert Type 2 DV to Type 1 (DVdate?)
By nlec in forum Video ConversionReplies: 30Last Post: 30th May 2007, 14:52
