I just got an ATI DV Wonder firewire card that included a full version of Ulead VideoStudio 5. At $40, I thought it was a good deal. My problem is, I'm trying to capture video from my dv camcorder, but the avi that's created using VideoStudio is very jumpy in some places and it looks like several frames have been dropped. I've read all I can on VCD help, but haven't come up with anything that will help. I tried to use VirtualDub to do the capture, but it won't recognize the firewire card. If you could help me out, I would greatly appreciate it.
Thanks!
Sorry I didn't add this to the first post. I'm using win98se, athlon 700mhz, 20 gig hard drive, 384 mb ram. thanks!
Have you defragged your harddrive? This seems to make a significant difference in analog capture. But I'm not sure if this applies since you are using DV. It should copy everything without dropping frames (my guess).
DV requires you to have a pretty meaty harddrive, I think it needs a sustainable 3.8mb/s transfer speed, but I could be wrong. Apart from the usual defrag and enable DMA you may consider getting a dedicated capture drive.
Analog capture with Studio Pinnacle 15HD, Dropped frames?
By rivrbyte in forum Capturing and VCRReplies: 2Last Post: 31st Dec 2011, 15:00 -
Virtualdub VCR capture no dropped frames but 5400 inserted frames in 1 hour
By suloku in forum Capturing and VCRReplies: 12Last Post: 17th Aug 2011, 22:33 -
Pleas Help with intensity pro capture dropped frames issue
By jub2k3 in forum Capturing and VCRReplies: 14Last Post: 18th Jun 2010, 12:38 -
Pryo DV capture adds tons of blank frames in between dropped ones.
By Knightmessenger in forum Capturing and VCRReplies: 11Last Post: 18th Jul 2009, 16:08 -
Jumpy playback, dropped frames during capture, CPU pegged to 100%
By tylerz in forum Newbie / General discussionsReplies: 7Last Post: 24th Jul 2007, 17:09
