I have a GMA-4020B DVD-RAM drive in my PC that I burned a few DVD-RAM discs with about a year ago.
I tried to read the discs in the same drive just tonight and I can not get the drive/system to recognize the discs.
Is there someway to read these discs? I tried CD/DVD Diagnostics program that I d/l'ed from Download.com, but I can't even get the trial version of that to run (seems others had the same issue according to the reviews I read on Download.com).
Is there any suggestions on what to do? I know the drive works, I use it everyday to read other discs...
Results 1 to 11 of 11
Do you have the DVD-RAM driver loaded? If you've redone your system since you burned these disks, maybe it's not loaded. Last I heard though, they were a bit hard to track down. If you still have the included software, that should work.
Nothing can stop me now, 'cause I don't care anymore. -
hmmm... never thought of that - the drive is original to the system (Gateway model about 18 months old).
I don't recall changing anything, but I will see what I can find in the original recovery discs
Thanks. -
The system does have the latest drivers and firmware for that drive - still no luck in reading the RAM discs.
Do you see a DVD-RAM service listed in Computer Management under Services?
No... Nothing there mentions DVD-RAM under Service name or Description. I assume that it would say DVD-RAM in either of those columns?
I did notice the IMAPI CD-Burning COm Service is active and set to manual. -
Make sure its listed in your bios. Then delete the primary or secondary controller (the one its on) & restart your computer & see if it detects it again. Can take a few minutes.
The drive detects the discs - it just will not read the three RAM discs that I have written to and were readable before.
The drive will read and burn CDs and DVD's with no problem - but will not read the RAM discs that I created with this drive about a year ago.
Have done no updates to the drive itself... -
Do you have any more disks?
Write one and see if you can read it. They SAY RAM disks will last a 100 years. Be a hell of a note to learn they don't last a year and a half, huh?
Cheers,
George -
yeah, it sucks....
I'm looking for the original system disks that came with the thing 2 years ago... If I can find them, I'll see about reinstalling drivers from there. I take from viral1 that I should have a service running on it to work the RAM drive with RAM discs, and those discs might have that stuff on it.
I can't remember ever uninstalling anything related to the RAM drive.... I did use Nero to write the discs, that's all I've been using for a few years now.
I did a search on google for the drive and could not find anything but a couple of articles about the drive - even the LG electronics website has little or nothing on it to help. No drivers, nothing.
DVD-RAM 10x, 12x discs - who sells them?
By rjamesd05 in forum DVD & Blu-ray WritersReplies: 6Last Post: 15th Sep 2009, 21:56 -
DVD-ram 2.8GB discs rip trouble
By wodfer in forum DVD RippingReplies: 1Last Post: 27th Jun 2008, 12:49 -
how do i copy DVD RAM discs to pc hard drive (retaining exact file quality)
By mnbvc in forum Authoring (DVD)Replies: 3Last Post: 19th Apr 2008, 17:32 -
DVD-RAM discs causing Panasonic DMR-ES10 recorder to 'fall-over'.
By dreamcloud9 in forum DVD & Blu-ray RecordersReplies: 13Last Post: 6th Mar 2008, 23:24 -
Philips 20X SPD2413BD won't read 8cm DVD-R discs
By nlec in forum DVD & Blu-ray WritersReplies: 1Last Post: 5th Jun 2007, 11:03
