Thanks for all the help on trying to capture a picture from a VCD. I figured out I have an out of date powerDVD. I have a program Riptide and it looks like I have capture the picture I want. I save as a jpg but when I open it, the frame around it is there but the picture is black. Would changing the resolutions,or other settings help or should I just give up until I upgrade.
Quick and easy way I do it is to just load the mpg into Virtualdub and go to the frame I want to cap. Hit PrtScn and paste into Photoshop.
His name was MackemX
What kind of a man are you? The guy is unconscious in a coma and you don't have the guts to kiss his girlfriend? -
Try Clip-Snipe (http://clip-snipe.sourceforge.net). While it's primarily an editor, it will also do captures (and the price is right- $0).
first Copy the vcd movie to HDD. then play the file by vcd cutter 4.03 and move the slider or hold Arrow key for snap a frame. when desired frame U view on screen, release arrow key and hit F4 or click snap buttom. It will extract your frame and save it in BMP format to default folder.
At last you use Photoshop to edit your picture.Little Baby -
Many ways to skin a cat: Play it with PowerDVD, use the snapshot function.
/Mats -
Yet another way is if you have a good image editing app they always have screen capture utility's.
Capturing with Hauppauge HVR-1600 using s-video: granular picture
By Skysis in forum Capturing and VCRReplies: 7Last Post: 25th Apr 2011, 19:54 -
Capturing picture from video
By aruwin in forum Capturing and VCRReplies: 1Last Post: 24th Apr 2008, 09:26 -
Picture "rolls" when capturing (video included)
By scully1888 in forum Newbie / General discussionsReplies: 1Last Post: 15th Dec 2007, 11:52 -
vcd playback - flickering picture on one dvd player, fine on another
By i_ming in forum Newbie / General discussionsReplies: 5Last Post: 21st Oct 2007, 07:41 -
No Sound and black & white picture capturing VHS
By gdkcl in forum Capturing and VCRReplies: 0Last Post: 30th Jun 2007, 13:07
