I am experiencing some frustrating problems with a couple of codecs.
In a nutshell. Running Win2K with 512meg and an ATI Radeon DDR with 32meg. Using Adobe Premiere 6.01 for video editting.
At one time, I was able to successfully using the Ligos Indeo 5.11 within Premiere. I recently had to do a reinstall of my OS and now Indeo 5.11 doesn't work properly. Basically I can play an Indeo 5.11 clip in the clip window, but the minute I do a compress/decompress to convert it to something else (like MPG4V2) I only get audio with a black screen. Anybody got any ideas on this one?
2nd problem. At the same point, I was able to successfully install the Divx40a50 codec and be able to render in those within Premiere. Again, after the reinstall of the OS, Premiere does see those even though the codec install itself appears to work okay. Again, anybody have any ideas?
Any help is appreciated.
Results 1 to 1 of 1
VFAPI Codec Problems
By [K]eep[A]way in forum Newbie / General discussionsReplies: 20Last Post: 8th Sep 2011, 07:40 -
Converting MOV to FLV - codec problems
By communique in forum ffmpegX general discussionReplies: 5Last Post: 13th Jun 2008, 15:58 -
Codec problems via website only ?
By yukon33 in forum Newbie / General discussionsReplies: 1Last Post: 26th Feb 2008, 15:19 -
Codec Problems
By Armadillo in forum Video ConversionReplies: 7Last Post: 12th Dec 2007, 13:42 -
Codec problems after installing k-lite
By woolf-gang in forum Software PlayingReplies: 9Last Post: 28th Sep 2007, 09:56
