  1. Hi,
    I've read the guides already but I can't get the chapters to work. I've tried to play it in powerdvd but all I can push is 1 only.
    I have an intro, a menu and a bunch of videofiles, all are in mpg.
    I want that after playing the intro and menu, i can push like track 10 on my remote and track 10 will play. And when I push "return" it will automaticly return to the menu. And that after playing one track the next track will play automatic. And after the last track it automatic returns to the menu. I've tried many different things in "interactivity" already but none does what I want. I'm using the 2.0.1 commercial version btw.
    Anyone could help me?
    thank you very much
    Australia
    OK for this example say you have Intro, Menu, Clip1, Clip2, Clip3 and you want key1 to goto Clip1, key2 to goto Clip2 and key3 to goto Clip3.
    To set this up select the 'Interactivity' option.
    TO SET UP THE NUMERIC KEYS: (You need to overide the default since it only uses key 1) ..
    In the 'Play Item' select your "Intro" clip.
    Tick the 'Overwrite this default assignment' at the bottom of the screen.
    In the 'Key' list click on the play item for Key 1 and make sure that it says Clip1.
    Click on the play item for Key 2 and select Clip 2 in the drop-down list.
    Click on the play item for Key 3 and select Clip 3 in the drop-down list, and so on ..
    Now click on the button next to the 'Overwrite this default assignment' (the one with 3 dots [...] on it) and click on the 'Select all items' and press OK.
    TO SET UP THE 'RETURN' KEY:
    With the 'Intro' clip still selected in the 'Play Item' list, make sure that the 'Menu' is selected in the 'Return' drop-down list, then click on the [...] button next to it and make sure that 'All items' are selected, and press 'OK' to activate it.
    TO RETURN TO MENU AFTER LAST CLIP:
    In the 'Play Item' list select the last clip, then on the 'Next' drop-down list select the menu.
    Now when you play the CD no matter where you are the keys should operate as you want them to.
  3. thank you very much!
    I've managed to create it successfully.
