I have an avi file that is 30fps 352x240 pixels. (44100 Hz audio / stereo 16 bit)
I want to use VirtualDub as a frameserver and fix the fps to be 29.97 fps
(Don't know exactly how)
also there are 4 lines at the top and 8 lines at the bottom that I want to paint black over... perhaps with aviSynth I can do this.
In the end after all the frame servers are running (And I'm not sure which order I should do this in.) I will use TMPGEnc to produce the 1150 kbit/sec MPEG-1 file. I have about an hour of video so I'm thinking this should be able to fit on a CD-R.
Suggestions/Help please.
Well, since you already have Virtual Dub up and running, why not add a null transform filter and crop off the lines you need to go? Then go ahead and frameserve normally?
Hello. -
Well if I chop off the lines then the resolution will no longer be 352x240.
Yes it will still be 352x240.Originally Posted by JustSomeGuyI think,therefore i am a hamster.
making a good quality avi from ts, vob etc
By pooksahib in forum Video ConversionReplies: 8Last Post: 11th Sep 2011, 09:41 -
Making a VCD to send to the Philippines
By StrikerZERO in forum Authoring (VCD/SVCD)Replies: 17Last Post: 7th Dec 2010, 10:11 -
Making sure AVI is compatible with DVD players
By uniks in forum Newbie / General discussionsReplies: 1Last Post: 25th Jul 2009, 18:31 -
joining/making movie from 2 cds into one with AVI,S
By keithportsmouth in forum Newbie / General discussionsReplies: 1Last Post: 24th Jul 2008, 13:51 -
Making VCD Copy
By audiophile in forum Authoring (VCD/SVCD)Replies: 5Last Post: 18th Sep 2007, 08:20
