How do u convert pcm to mp3 format using virtualdub?
Is this possible while you are encoding the the video?![]()
Choose streams/stream list and right click on the audio and choose full processing mode,then right click again and choose compression.
^ https://www.videohelp.com/tools/Lame-MP3
Next time, please *don't* bump VERY-OLD THREADS. -
I'm pretty sure the Windows/Microsoft MP3 encoder is the one highlighted in auto7890's screenshot.
I assume it's not configurable in later versions of Windows (I'm guessing and I have no idea what the output will be), but even though the XP version
is configurable, I'm pretty sure it's limited to very low bitrates.
If you manage to get the LAME ACM MP3 encoder installed (not the standard version), VirtualDub(Mod) will list it too.
If you've only got an AVI or two to worry about then it might be less hassle in the long run to extract the PCM audio from the original AVI
and convert it with something which isn't VirtualDub(Mod). Add the newly encoded MP3 as an audio stream while disabling the existing PCM,
then edit and encode the video as you normally would.
what is the difference between PCM & MP3
By ashe09 in forum Newbie / General discussionsReplies: 2Last Post: 25th Feb 2012, 07:50 -
mkvmerge treating mp3 as PCM?
By shun in forum Video ConversionReplies: 0Last Post: 31st Mar 2011, 03:42 -
I need an idiot's guide to converting PCM to AAC or Vorbis!!!
By Nagashi in forum AudioReplies: 6Last Post: 4th Jul 2010, 17:07 -
Trouble converting AVI(divx)+MP3 to FLV+MP3
By BLboy in forum Video ConversionReplies: 7Last Post: 21st Jul 2009, 04:36 -
Converting songs purchased on itunes and converting to mp3
By maroonx in forum AudioReplies: 1Last Post: 23rd Jan 2008, 00:17
