I'm trying to make an ISO image of a dvdr I've made. I'm using dvddecryptor to create the image. The problem is the dvd was made on the horrible Prodisc R03 media, and when decryptor gets to 98% it its errors (retried 18 times). Anyone know how I could get this dvd back on my computer?
Results 1 to 11 of 11
What We Do In Life, Echoes In Eternity....
Try ripping it to yr HDD in file mode and determine which file it's choking on.
You coul strike lucky and find it's only an.ifo or.bup file, in which case you can easily use it's counterpart with a rename to rescue it.
Also if you haven't already, try ripping with your burner. -
Settings - I/O - Ignore Read Errors
You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off. -
I am ripping with my burner to my hard drive.
Phil Thomas, what do you mean by "use it's counterpart with a rename to rescue it. "
tompika if I do that will it rin the movie at all? Will movie still play?What We Do In Life, Echoes In Eternity.... -
Right ... if it's an .ifo or example that it cant read .e.g. VTS_01_0.IFO then just copy the corresponding .bup file e.g.. VTS_01_0.BUP out of the folder and rename it to VTS_01_0.IFO and move it back in.
This will work because the content of .ifos and .bups is identical.
Hope that makes sense. -
Well, I just ripped a movie yesterday with hundreds of errors (it took four hours) but it played almost OK. There were some pixellated scenes in it but no real big deal.Originally Posted by Denvers Dawgs
I wish you good luck.You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off. -
so just take the corrupted .bup out of the folder rename it as an ifo? why is this confusing me seems very easy....Originally Posted by Phil ThomasWhat We Do In Life, Echoes In Eternity....
BUP is the backup file for IFO
oh ok.....thats why i was confused didn't know bup was a back up file....BUP= Back Up _?
When I rip it to the drive in file mode how will I know which file its chocking on...Originally Posted by Phil Thomas
tompika "BUP is the backup file for IFO"
oh ok.....thats why i was confused didn't know bup was a back up file....BUP= Back Up _?What We Do In Life, Echoes In Eternity.... -
Easy Way = Watch it, it tells you which file it is working on.Originally Posted by Denvers Dawgs
Hard Way = Skip when it has a problem and compare copy to original and see which file is missing
How to fix/edit a damaged video iso?
By hibbs in forum Newbie / General discussionsReplies: 8Last Post: 20th Jul 2010, 16:24 -
Scan and Fix a DVD that has some errors
By ppeterr in forum Authoring (DVD)Replies: 5Last Post: 21st Apr 2010, 02:38 -
DVDFAB Platinum 6 . . . no process for saving an ISO to the hard drive? :(
By MISS CHIEVOUS in forum Newbie / General discussionsReplies: 1Last Post: 10th Sep 2009, 09:44 -
Trying to create a process for creating home movies reliably and need help
By Arphahat in forum Newbie / General discussionsReplies: 1Last Post: 16th Feb 2009, 11:19 -
Burned DVD ISO playback errors
By Silver_Ice in forum Authoring (DVD)Replies: 1Last Post: 9th Aug 2008, 13:24
