i got a problem an its this:
i got a coupla files one with a framerate of 23.976 the pther with 29.97, both are mpegs. when i try to encode em, the resulting files come out with horizontal lines comin outta the moving images. im pretty sure this is somathin to do with interlacing. how do i correct this annoyance using tmpgenc plus? thanx
Results 1 to 15 of 15
You don't. You correct it by viewing it on a TV as it was intended.
yup looks like that 'cept maybe a bit more pronounced and the lines only become apparent when theres motion in the scene. ive burned to the file to disc and ots still there when i play in my dvd player. any ideas how i can correct this? maybe run the file thru tmpgenc again and select deinterlace?
Don't select deinterlace if you're planning to watch on a TV. I think it's either interlacing, or perhaps you have the wrong field order selected, because this tends to only show up when there's movement, whereas interlacing shows up even when the scene is still.
If in doubt, Google it. -
im redoing the file with the field order reversed ill let u know how it turns out
thanx for ur help jimmalenko...you were spot on it worked a treat, i know where to come to next time!
yes, changed the field order and hey presto...no more lines. thanks again bro
The next time you have a field order problem you can just use restream on the video portion ot the file to change the field order. Only takes a few minutes then just multiplex your new video file with the audio and your ready to author!
Donadagohvi (Cherokee for "Until we meet again")
Unique lookin video-editing soft
By perfect-bue in forum Latest Video NewsReplies: 0Last Post: 7th Apr 2009, 05:01
