  1. Hi,
    Is there any way to rotate back an avi videoclip with 90°. I turned the camcorder when I recorded the clip because it was the only good choice. Then I transferred the file to the PC into a big avi file, but the clip is still rotated and I would like to turn it back to the normal view.
    Which software can do it for me?
    Thank you for your help in advance.
  2. Member vhelp's Avatar
    Mar 2001
    New York
    One way, is by using vdub. You can load up the rotate filter that
    comes already w/ vdub, and select with ever direction you need to go in...
    (o) Left by 90°
    ( ) Left by 90°
    ( ) Around by 180° - flip up/down
    -vhelp
  3. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    Virtualdub will do it. Go to filters - add and select ROTATE. This will let you rotate it any direction you need to.
    Kevin
    Dec 2004
    Australia
    AVISynth:
    avisource("clip.avi").turnleft()
    No need to convert to RGB24 that way.
