Although this is not the DVD standard, is it possible to author a DVD video with mp3 audio?
DVD-Lab only lets authoring 48 or 96 kHz mpeg layer 2 files (mp2), but is there any other program letting mpeg2video+mp3audio combinations?
I guess that as almost every standalone dvd player also supports mp3 files, the resulting dvd would be readable.
Is it possible? Thanks!
Hello,
Nope - for dvd video the audio it accepts at the 48khz levels are:
AC3
PCM
MP2
That's all.
A .MPA (MPeg Audio) file IS MP2 - don't confuse the file extension with the compression codec! WordPerfect used to create .DOC files, but they weren't the same as MS Word files by any means
Trev -
MPA is the same as mp2.
As for MP3 DVD authoring, I'm yet to see an authoring tool that allows this, as it makes a mockery of the DVD spec if it did.
A couple of things spring to mind:
You can create MPEG-1 Layer 3 audio when encoding an MPEG file (before authoring).
Not all players that play MP3 can play MP3 off DVD either.
If you were to get a player that plays raw MPEG, you just might be able to get it to play.If in doubt, Google it.
By MGadAllah in forum Video ConversionReplies: 1Last Post: 28th Jul 2011, 17:43 -
XIVD cannot output video with MP3 audio
By pchan in forum Video ConversionReplies: 6Last Post: 25th Sep 2009, 11:51 -
MPEG2 Video with AC3 audio cannot convert to MP3 audio
By wenglock in forum ffmpegX general discussionReplies: 0Last Post: 7th Sep 2009, 22:52 -
Converting an AVI video with AC3 audio to an AVI video with MP3 audio
By rijulHKG in forum AudioReplies: 1Last Post: 15th Jul 2007, 01:23
