I have tried everything I can think of with this one disc. It gets about halfway through VTS_01_2.VOB, then quits with read errors. I have tried DVDShrink, DVDDecrypter, cleaning the disc... none of it works. Does anyone have any suggestions?
"It's getting to the point now when I'm with you, I no longer want to have something stuck in my eye..."
Given you were in *that* thread a couple of days ago, obviously you should know (and I'm guessing, have tried) all the methods listed there. Is this on DVDR or a store-bought ?
Maybe try a different DVD drive if possible ?
smartripper or VOBBlanker ?If in doubt, Google it. -
I have tried four different drives, and they all claim a CRC error (maybe my vision is getting worse, but none of the scratches look that deep). I will try Smartripper next and see how that goes. And no, I don't think *that* thread applies, because this disc was made in 2003 or so.
"It's getting to the point now when I'm with you, I no longer want to have something stuck in my eye..." -
All worth trying;Originally Posted by Nilfennasion
- All the different ripping tools
SmartRipper, DVD Decrypter, DVD Shrink to name but a few, and even Cut+Paste in Windows explorer
Cleaning the disc carefully and thoroughly (if the scratches are shallow)
Using toothpaste (if the scratches arent shallow)
Using a different drive (in mates PC if necessary)
Cleaning the laser lens
Having the disc playing in the background whilst ripping (this slows it down A LOT, but might work)
Zworg2 - All the different ripping tools
In DVD Decrypter, have you tried checking the Ignore Read errors box? Under Tools, Settings, I/O on my out of date version. I've managed to rip a DVD that would play but kept failing when ripping by doing that.
Things I have tried so far:
Four different DVD drives (LG GSA-4120B, LG GDR-8163B, a Pioneer DVD±RW, and a Lite-On piece of junk).
Putting the disc through a repair kit no less than seven times.
Smartripper (which I found impossible to worth with anyway), DVDShrink, DVDDecrypter, and AnyDVD.
Given the importance of the disc, this is starting to get a bit frustrating.
Sounds like you are probably going to need to take it back and exhange it if possible.
There is that occassional disc that just wont work. What I could recommend above above the other suggestions, would be to let the ripper cool down and then try it again. What I have done is open 2 sessions of dvddecrypter and then when it got to a bad spot, pop the thing out let it cool , clean the disc and then try again later. -
I would ask if it would be possible to rig an external device such as a DVD player to the computer and capture from that source, but that is sounding like more trouble than it was worth.
DVD plays, won't rip (now rips with CDRoller, won't import to TMPGEnc)
By koberulz in forum DVD RippingReplies: 14Last Post: 4th Dec 2011, 10:42 -
DVDFab won't rip
By pepegot1 in forum DVD RippingReplies: 5Last Post: 4th Sep 2010, 15:34 -
Rip won't start
By audax in forum Authoring (DVD)Replies: 3Last Post: 20th Jun 2009, 03:41 -
DVD's that won't Rip
By wulf109 in forum DVD RippingReplies: 1Last Post: 15th Sep 2008, 23:30 -
Is it possible to rip a HD DVD disc to Hard Disc ?
By fjmr in forum Newbie / General discussionsReplies: 3Last Post: 13th Sep 2007, 13:50
