I'm having a problem with certain .avi files I try to rip the .wav from. I use virtual dub and when I try to get save the sound to .wav it ends up not fully copying it. Currently I have aprrox. a 120 min file and when I save the .wav only 37min of sound saves what should I do?
Bad frames in the source? Just a guess...
Scan using VirtualDub and see what it says...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room.
decode 5.1 matrix surround wav file to 6 mono wav files
By Zerrax in forum AudioReplies: 2Last Post: 24th Nov 2013, 07:39 -
VirtualDubMod and Save WAV problem...
By bla4free in forum AudioReplies: 7Last Post: 9th Oct 2008, 15:53 -
problem importing wav into EditStudio
By ecc in forum EditingReplies: 4Last Post: 20th May 2008, 14:41 -
Ripping a CD to wav files.
By efiste2 in forum AudioReplies: 6Last Post: 2nd Nov 2007, 17:31 -
Audio problem with WAV files
By vertical in forum Newbie / General discussionsReplies: 5Last Post: 8th Jul 2007, 17:47
