Dear all.
how is conversion to text-based subtitle using OCR done?
R there different kinds of OCR method for this purpose? Where can I find websites that shows the concepts or algorithms behind it? Any suggestions?
I've tried searching the net but all it returns me are how to do them using third party softwares. I hope to learn the concepts behind this process.
Besides using OCR algorithm, are there other ways of converting DVD subtitles to text?
also anyone knows what is the *.idx file all about?
Please help!!![]()
I guess the idx file contains time or frame info for when the individual subs should be displayed...
As for OCR you either buy a component or create your own, like I think the author of Sub Rip has done. OCR is the only way, as DVD subs are images.
Mats
Subtitle Edit question about OCR using a french dictionary
By jesant100 in forum SubtitleReplies: 1Last Post: 9th Jul 2011, 13:25 -
Author AVCHD with simple text-based menu?
By litmus in forum Authoring (Blu-ray)Replies: 1Last Post: 28th Feb 2010, 18:52 -
DVD subtitle to text file
By hardy in forum SubtitleReplies: 3Last Post: 27th Jun 2009, 20:31 -
looking for good OCR software that will convert text in jpg to regular text
By jimdagys in forum ComputerReplies: 6Last Post: 27th Jun 2008, 11:38 -
Split DVD into movie clips based on timing info in subtitle file.
By kwazi in forum Authoring (DVD)Replies: 1Last Post: 20th Feb 2008, 11:27
