  1. I used to have software that could convert bin/cue to avi, but I formatted and forgot to back if up. Now I find myself looking for it. Can someone help me find a program that help me convert the bin/cue to an avi.
  2. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    https://www.videohelp.com/forum/viewtopic.php?t=233348
    BTW, bin/cue is just a disc image format. Inside it could be AVI, MPEG, WMV... anything really. What you need to do is read that link I posted, which tells you how to extract what's inside the bin/cue, and then once you know what you have, look in the convert guides for whatever type it is to AVI.
    If in doubt, Google it.
  3. I'm a Super Moderator johns0's Avatar
    canada
    Hard to say what progran you need,bin/cue files can be games,vcd,svcd.Do you need to extract an mpg and convert to avi?Isobuster will extract files from a bin/cue image file.
    Jan 2004
    Spain
    VCD gear is a nice simple free programme, works for me.
  5. Thanks guys I really appreciate the help
  6. You can open it with Daemon Tools.
    Ypu can also burn it directly with Nero (Burner->Burn Image from disk and select the cue file).
