I've got a DVD-r I backed up with DVD shrink it plays find on my TV. However when I put it into my computer I can only watch the first half using like Win DVD or Windows media player etc. After that it goes into slow motion or something where it just freezes for about a min then goes to the next screen seven seconds later and so on. I've also tried copying it with like Smart Rip and an error pops because its not unlocked but I can’t unlock it because playback doesn’t work. And I've tried just copying the DVD to another DVD with Nero disc copy it stops about halfway though and says there was an error and it had to abort or something like that. Obviously there is an error but it doesn't effect watching it on my DVD player so it seems there would still be a way to burn it at least to me it would make sense. Any help is much appreciated thanks,
Overbound
or cleaning the disc, or checking for scratches, or cleaning the laser lens.Originally Posted by funkguy4
standalone and PC DVD drives have very different error compensation
standalone may just skip past what the PC might choke on... -
Sounds like it could be a media issue/bad burn and your drive is having read error trouble.
Try using DVD Decrypter in file mode to rip the files to a folder on your HDD ... if successful, burn from there .... if you get read errors galore it's the disk
Try ripping with your burner instead of the DVD-Rom, these are generally more forgiving. -
Thanks for all your sugestions but the first one work. I installed my old dvd drive and it works on that thanks alot
run a laser lens cleaner on all, even standalone optical drives. i've had dvd\r's that gave me a problem on my pc. lens cleaner fixed it instantly. lens cleaners are a must if you sit by your pc smoking all day!!!
Backing up files
By didikai in forum Newbie / General discussionsReplies: 19Last Post: 3rd Nov 2011, 09:17 -
Backing up files
By Deathstrike in forum ComputerReplies: 4Last Post: 5th Jul 2010, 22:16 -
Backing up old VHS
By ClarkWGriswold in forum Video ConversionReplies: 5Last Post: 31st Dec 2009, 14:33 -
Backing up a DVD
By kschwi in forum DVD RippingReplies: 19Last Post: 29th Nov 2009, 10:15 -
backing up footage
By JJJewel in forum Video ConversionReplies: 5Last Post: 25th Oct 2009, 08:26
