I decided to run another test using the ATI MMC for capture. I'm trying to make sense out of all this and I know that higher bit rates should make the result better. I have also read several threads discussing the merits of capturing in 352x480 vs. 720x480.
I did 6 captures of the same 5 minutes of 8mm video with different resolutions and bit rate settings. The constant settings were as follows: MP2-DVD, encode interlaced, no 3:2 pulldown, record cropped, 48k stereo, 4-2 closed GOP, motion estimation quality 100%, Audio 256k and no video soap.
Test 1: Res: 352x480 Bite Rates: Max 4M Target 3.5 File size: 145mb
Test 2: Res: 352x480 Bite Rates: Max 6M Target 5.5 File size: 239mb
Test 3: Res: 352x480 Bite Rates: Max 8M Target 7.5 File size: 317mb
Test 4: Res: 720x480 Bite Rates: Max 4M Target 3.5 File size: 143mb
Test 5: Res: 720x480 Bite Rates: Max 6M Target 5.5 File size: 237mb
Test 6: Res: 720x480 Bite Rates: Max 8M Target 7.5 File size: 333mb
Referring to the bell-curve graphs found at http://www.digitalfaq.com/capture/avivsmpeg.htm I really was not expecting to see an increase in quality on the 352x480 captures by raising the bit-rate. I did however, expect to see an increase in quality of the 720x480 captures as the graphs indicate. I authored and burned all of these as different chapters using Nero and viewed them on the TV.
Results
For the most part, all of these captures look the same.
1) I could see no difference in the 352x480 tests 1, 2, and 3. Wasn't really expecting any though.
2) I could maybe tell a very small gain in quality on the 720x480 tests 4, 5 and 6 as I raised the bit-rate, but it was very small. According to the bell-curves, if I am reading them right, there should be a large increase in quality up to a bit-rate of 8M.
3) I couldn't really see any difference when comparing the 352 and the 720 captures.
I would really appreciate any insight, opinions and tips regarding all of this.
Questions
Am I on the right track here? Really thought I would see some big differences in quality on the 720x480 captures with the different bit-rate settings.
Is it possible Nero is doing something to the files? (I think re-encoding is the proper word), but I don't believe this to be the case.
I know this is very subjective, but I still am wondering what folks around here consider to be a good quality capture from analog material. I would estimate that I have about 90% of the source quality-wise.
- VBR will alter this slightly
- active capture is not a good test for this
- ATI MMC lies about bitrate sometimes
- your source can determine some of this
What is Nero doing? Why is this part of your equation?Want my help? Ask here! (not via PM!)
Bitrates are close to capture settings- I just viewed the DVD in PowerDVD and the info shows they are.
So you are saying that with a source like 8mm, raising bit rate to an indicated max of about 8 may not help much on a 720x480 res capture, but in theory it would.
Nero- just wondered if Nero re-encodes the MPEG files before it burns. From reading here, I know that some programs re-encode files, but I think this applies mainly to editors?
Is my ATI TV Wonder 650 damaged, or did I just pick a bad test tape?
By Mini-Me in forum Capturing and VCRReplies: 17Last Post: 6th Dec 2010, 23:54 -
[b][url]TEST! TEST TEST! WHAT"S THE BEST?!!!!!!!111111
By lordsmurf in forum TestReplies: 0Last Post: 2nd Aug 2010, 02:30 -
How 2 Capture HD with ATI HDTV Wonder
By NautTboy in forum DVB / IPTVReplies: 41Last Post: 2nd Apr 2010, 12:38 -
Resolution Test - BT878 - ATI Rage Theatre - Philips SAA7130
By BrainStorm69 in forum Capturing and VCRReplies: 3Last Post: 23rd Mar 2010, 06:10 -
Any Capture Card Still Run Under Win98?
By Ensign in forum Capturing and VCRReplies: 9Last Post: 17th Sep 2007, 12:16
