does anyone know how to set up sound for a card with just svideo in? i have this card and on my motherboard it has spdif inputs but i cant seem to get the sound to work when using it. Also ati mmc will not let me see the video on the card although in the setup it will let me pick the card as the capture device
You configure MMC in the sound configuration for what input your using, also make sure whatever input on the soundcard you are using is enabled in the soundcards configuation.
the problem im running into is that on my cable box i have svideo out and composite out for the audio. And with the asus card it came with a little box that you plug into the capture card and on the box it has some plugs that your supposed to plug in your cables but none of the plugs are for audio because the card seems to capture vidoe but not audio. How do i hook up my compostie cables into my computer so that when i start up mmc or asus vcr or whatever capture software im using that i can get some audio. I have 6 outputs on my onboard soundcard that are for regular speakers and two rca jacks one that says spdif out and spdif in. thanks for the help guys
Are you sure they are all outputs..... Mosty likely at least 1 or 2 are for input. The six mini-jacks is exactly what I have. 3 for 5.1 surround, 2 for input and ! for external output.Originally Posted by bgates222
You only need a RCA to mini-jack adapter which you plug into the soundcard mic input or aux input. You can get one at Radio Shack or just about any electronics store. -
god im stupid your right lol now that you say that . The adaptor i never even thought of that just plug that into my line in lol damn thanks
now i ave to figure out why mmc says i dont have the correct direct x and it cant initialize the video even tho it does see my card lol maybe ill just use the asus vcr since it sees the video at least. do you know any other capturing programs? besides really advanced stuff like premiere
discrete sound card vs onboard quality
By mammo1789 in forum AudioReplies: 1Last Post: 17th Dec 2011, 08:53 -
No MS-DOS sound in Current set-up
By Frank-0-Video in forum ComputerReplies: 13Last Post: 9th Jun 2011, 09:16 -
What are the downsides to having both onboard sound and Sound Card enabled?
By c627627 in forum Capturing and VCRReplies: 0Last Post: 21st May 2010, 15:44 -
eeeK! Asus alerts new owners to onboard malware
By ahhaa in forum ComputerReplies: 0Last Post: 11th Oct 2008, 09:28 -
AC3 sound - worked in software, didn't on set-top player
By dadrab in forum Authoring (DVD)Replies: 12Last Post: 25th Feb 2008, 09:15
