hey all,what is the best free video editor (and, or source creator)
out there?
best meaning highest performance not speed.
thx a lot
Results 1 to 16 of 16
https://www.videohelp.com/edit
Ya got some reading to do
Cheers, Jim
My DVDLab Guides -
I've got one called Edit Studio. I've had a play with it and although it doesn't do as much as I need, it's still pretty good and straightforward to use. The current version 4 isn't free, but I got a free, full function version 3 on a CD on the front of a PC magazine.
Virtualdub is the cheese for me.
Best to specify what file types you are editing next time you post a question.Might want to try cutterman.Originally Posted by MIKEMANI think,therefore i am a hamster.
basically th main vid types (avi,mpg,vob to vcd , dvd).
who or what is cutterman?
thx -
Look to the left and click on tools and enter cutterman.
That's CuttermaranOriginally Posted by MIKEMAN
"Just another sheep boy, duck call, swan
song, idiot son of donkey kong - Julian Cope" -
try VirtualdubMod, then - it will handle mpeg as well as .avi.
even if you go with another tool, download Virtualdub and keep it around - it's the Swiss Army Knife of video editing, I've found it's saved my bacon multiple times.- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
Both Zwei-Stein & Avisynth are good.
Later!
RogThere are many ways to measure success. You just have to find your own yardstick. -
i second that avisynth, although u'll need the mpeg2dec3 plugin or something. idk what zweistein, so i can't comment onthat. mpeg aint' much of an editable format though (unless they're small, closed GOP), just a heads up. VirtualDubMod is nice graphical and free, but it only outputs RGB. What i like to do is look what i need to do in VDubMod, then transfer it to an AVISynth script. Sorta like a weird kind of AVISynth GUI/editor thing. it might be able to make avisynth scripts though, i'm not sure on that one.Originally Posted by burnman99
No-one's said it yet, so I feel I should mention it - MPEG is what's considered an "end product" format, meaning that, after all the editing etc., that's the format that is used to deliver to the end user.
Therefore, MPEG isn't the best format to be doing your editing in. If you can, get yourself an AVI of the footage you want to edit, edit in AVI and then encode to MPEG.
If you can get AVI of your footage, all the links above referring to editors will be of use.
If you're stuck with MPEG, check out VideoReDo. Go there from the link on the homepage (near the bottom), that way the site gets a pay back I believe...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
but it is not possible with the software mentioned to edit frames....e.g. to make an unwanted person intruding the video to disappear...
KONX OM PANX
Best Free Video Editor
By Spiralagnus in forum Newbie / General discussionsReplies: 26Last Post: 27th Jul 2011, 19:42 -
Free video editor
By jazzygirl in forum Video ConversionReplies: 1Last Post: 16th Jul 2011, 01:54 -
easiest free mp4 editor
By angryassdrummer in forum Video ConversionReplies: 2Last Post: 5th Apr 2011, 03:38 -
Need free XP .mov editor
By BayouBill in forum Newbie / General discussionsReplies: 3Last Post: 26th Jul 2009, 08:22 -
Free VOB Editor
By acw in forum Newbie / General discussionsReplies: 2Last Post: 5th May 2009, 18:12
