What program would I use to convert an m2v file to an mpeg?
Thanks!
Im right there with you..been having problems trying to figure this out...i was told that with some .m2v files you can just rename the extension to .mpg. If anyone can help..please do...i know there is some simple answer i just cant find it
thanks
deckone
channel one recordings -
An m2v file should be an MPEG2 file which is video only; no sound. So are you trying to convert to mpeg1? Is it not working in terms of not playing on your computer or what? If you can't play on your pooter, try installing Windvd or another dvd player and play from there. The MPEG2 players like Ligos and Xing pale in comparison.
Anyway, to convert to another form of MPEG, your best bet is dvd2avi, save project, load into tempgenc and convert to your heart's content.
Matt -
Yes, I want to convert it to mpeg-1. I tried playing it on Windows Media Player, but that didn't work.
Transform .m2v +. wav to full MPEG-2 dvd spec file?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 2Last Post: 14th Oct 2011, 08:13 -
Convert/Mux .m2v and .wav into mpeg for DVD??
By Beavis in forum Video ConversionReplies: 2Last Post: 22nd Jul 2011, 14:46 -
help with ffmpeg args to convert .m4v to .m2v or .mpeg
By rhfritz in forum Video ConversionReplies: 3Last Post: 28th Apr 2011, 12:09 -
Freeware to mux mpeg-2 (m2v mp2) (NOT TMPGEnc)
By 2397to2997 in forum Video ConversionReplies: 12Last Post: 18th Aug 2010, 15:42 -
.m2v to .mpeg sound syc issues
By newsclips in forum Video ConversionReplies: 2Last Post: 5th Jun 2007, 13:36
