Hi I recently backed up a friends simpsons dvd onto my computer but
it made the iso file 6gig. DVD Decrypter wont burn it because its too big
and DVD shrink wont recognise the iso file to be able to shrink it.
Does anyone know how I can reduce the size or maybe half it so I can
burn it to dvd.
burn it to dvd. -
Very funny, my friend doesnt have a computer and was worried her kids
would damage the original. But hey why am I explaining myself to you for.
Please anyone with actual help out there would be great. -
...or u can use DVD Decrypter and rip in 'File' mode. DVDShrink will read those too
The distance between genius and insanity is measured only by success... -
Originally Posted by aussie8964
But beyond that as stated, DVD Decrypter and DVD Shrink will both work well for you.
Open the ISO in DVD Shrink and create new files and go from there.
Guides for both programs can be found on the left or here....
DVD Shrink DVD Decrypter -
Posted: Sun 01, 2005 03:31 *
Hi Aussie,
Use the following method.
1. Use Shrink to re-author and backup to a single ISO file.
2. Then burn with DVD Decriptor. (both applications are free)
Your drive should be formatted NTFS to enable you to create a single ISO file using DVD Shrink, then burn with DVD Decrypter. If your drive is formatted Fat32 you will need to split the ISO images into 1 gig files and then burn with DVD Decrypter.
No coasters, no skips or freezes and a backup that is hard pick from the original DVD.
Another Aussie
Problem burning .avi file to dvd.. Burner tells me file is too big when not
By accesskb in forum Newbie / General discussionsReplies: 17Last Post: 6th Mar 2012, 18:28 -
Avi2DVD help Iso too big
By martial4rtist in forum Newbie / General discussionsReplies: 12Last Post: 9th Apr 2011, 17:41 -
Tool recommend for *.avi ---> DVD(iso) and ripping a DVD to *.iso file?
By pxstein in forum Authoring (DVD)Replies: 4Last Post: 11th Jan 2011, 15:51 -
Why are my AVI2DVD dvd ISO files TOO BIG to burn onto DVD!?
By Xenogear900 in forum Authoring (DVD)Replies: 5Last Post: 1st Sep 2008, 21:20 -
ISO file to big for CD
By vagg in forum Newbie / General discussionsReplies: 3Last Post: 17th Sep 2007, 13:02
