  1. Hi, I created a few 5 episode dvds in dvdlab with a main menu, an episode select menu and then a menu with the episode name (play episode button) and a back button.
    When i came to play these dvds two of them have errors. One of the episode buttons actually links back to the main menu and on another disc i forgot to link to an episode so the button won't select. I can't view these 2 episodes now and have deleted the source files so is there anyway I can edit the menus to select the episodes without having to totally start again?
  2. Member adam's Avatar
    Sep 2000
    Its possible to change the button commands using MenuEdit but I think you'll have to purchase the full version for that capability. Its also fairly complex unless you've already got a grasp on what the different button commands do. Still, MenuEdit should show you what commands were used on the buttons that do work, so you should be able to figure it out with a little trial and error.
    An inellegant solution would be to turn PBC off on your player. This will allow you to browse all the different video tracks without using the menus. Then you can manually select the episodes that have the broken links. There should be a PBC option on your remote otherwise look in the player's setup. Some players have other methods of browsing just the tracks, like something called DVD Digest.
  3. Thanks, got it working. That'll teach me to check each link before I burn
