I want to create a DVD with approximately 3 hours of (mainly) VHS footage. I use a liteOn DVD recorder to capture and then transfer those files to TMPEG DVD Author to create a DVD with menus.
Should I use the highest quality recording mode (1 or 2 hour) to capture and then shrink the final DVD in DVD Shrink or just capture in the recorder's 3 hour mode without shrinking?
Hello,Originally Posted by RowMan
You'd probably be better off using the lower bitrate mode to capture under the limit first. That way you don't mess with the video. Because either way it will be a little less quality then top mode.
Because if you shrink it you're still introducing a lower bitrate to the picture. Why not start with a lower bitrate to begin with and make sure it's not touched much.... Just my opinion
KevinDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Aspect Ratio setting in VirtualDub Capture mode
By alesco in forum Capturing and VCRReplies: 34Last Post: 6th Feb 2012, 09:23 -
hd-dvd mkv rip comparison vs hauppauge hdpvr capture in 720p mode
By yoda313 in forum Capturing and VCRReplies: 3Last Post: 21st Aug 2011, 04:14 -
DVD Decrypter: File Mode total size double that of ISO read mode
By dare2be in forum DVD RippingReplies: 7Last Post: 13th Feb 2011, 12:21 -
Force custom resolution for TV out in CLONE mode for DV Capture ?
By TheParadoX in forum Capturing and VCRReplies: 4Last Post: 6th Oct 2008, 19:00 -
Capture card with 50 and 60Hz Mode
By nintendo in forum Capturing and VCRReplies: 8Last Post: 4th Jun 2008, 05:46
