Can you post the IFO related to this VOB? I am curious to see what the DVD shows as info for the video, as ChrissyBoy says, the 1024 width is well outside DVD specs.
Results 151 to 180 of 209
Dwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com -
I think it is an aspect ratio issue. I think if you open a command prompt and change directory to the folder containing the vob2mpg exe and do:
that should sort it...Code:ffmpeg -i "pathtoyourmpg" -vcodec copy -acodec copy -aspect 16:9 "pathtoanewfile.mpg"
@Jikchung: ifo file is here
The command Chrissyboy posted results in many bufferunderflows. But it makes an mpg. However, it isnt playable.... neither is it importable....
Is this maybe because i use wrong codecs, or maybe Sony has made some own-non-standard format ? -
Well, the IFO sees it as 720x576 - 16:9, which is as it should be. Where did you retrieve the 1024 pixels value from? It shouldn't be codec related, it's the aspect ratio and how it translates. It's one reason I stayed with tape and DV on my camcorder - but I'm a bit picky that way.
You say you want to get the videos online, what format are you aiming for? Depending, I might have a couple ideas for that.
ChrissyBoy probably has other things you could try. He's pretty busy elsewhere at the moment, so try to be patient.Dwight
- Herm Albright
Ofcourse i am patient; i think ChrissyBoy does a great job at thinking and offering solutions for ppl. Stupid i didnt say that before, should have started with it.
I got the 1024 width from Windows media player 9 from "file" -> "properties". The 720 width movies look like 16:9 movie played on a 4:3 ratio. All ppl are very thin.
I have some aims for this video editing:
- I want to get some clips out of the DVD to put them into small (maybe 320 witdh) mpeg or avi. The type aint so much important, as long as people can play them in windows media player with stereo sound. And ofc size matters; it shoud be smaller so it can be downloaded from the internet. If i am able to get the .VOB into Windows Movie Maker, then i can make clips and export them.
- I even might get involved in video editing and making home-dvd's. In fact, the 8 cm DVD's that come out of my camcorder can hold only 2,4 GB (Dual layer). So that i will have to combine them on normal size DVD's.
Maybe i went too fast by choosing Windows Movie Maker, but it is installed on my pc so it is the easiest start-up way for now. -
Try http://www.wincesoft.de/html/dvdpatcher.html to change the aspect ratio of the mpeg from 4:3 to 16:9
That did the trick ! The aspect ratio of the original is just wrong, and that last tool fixed it
)) Thanx Chrissy, you are a genious.
Now i start editing it in Windows Movie Maker; i have to cut all scenes since the information about the chapters was lost it seems. -
Great! Glad you got it going, good on ya, ChrissyBoy.
Dwight
- Herm Albright
Like to get an answer to something that bugs me and i haven't found the fix.
I've always used Anydvd and Recode to rip my DVD to my HDD. Once there i open VOB2MPG 2.3.
When i start the conversion, VOG2MPG immediantely says it's finished and i look in the folder and while there is a file created, it isn't of any size. Now this only happens maybe 1 in every 100 movies, but when it does happen I can't get that movie into 1 VOB to stream to my media extenders. I have tried restarting pc, closing out VOB2MPG , moving the ripped files to another HDD, uninstalling and reinstalling the software but the end result is, some ripped movies won't allow me to create a single VOG with this software.
Question is.............is there a fix or another way or program to get my files into single VOB for media center viewing?
Here is my log , the title that is giving me trouble is "War" , it was created by Nero Recode. TIA
[/code]Code:******************************************************************** ************************ SYSTEM INFORMATION ************************ ******************************************************************** ***************************** VOB2MPG ***************************** Name: VOB2MPG Title: Version: 2.3.0.0 Executable: C:\Program Files\BadgerIT\VOB2MPG\VOB2MPG.exe Executable size: 640 KB Executable size in bytes: 655360 Executable CreationTime: 3/14/2006 9:49:26 PM Executable LastWriteTime: 3/14/2006 9:49:26 PM Executable LastAccessTime: 7/17/2007 2:28:52 PM ****************************** Drives ******************************* DeviceID: C: FileSystem: NTFS Size: 279 GB FreeSpace: 170 GB DeviceID: E: FileSystem: NTFS Size: 3.18 TB FreeSpace: 1.03 TB ******************************************************************** ********************* END OF SYSTEM INFORMATION ******************** ******************************************************************** ********************** Input Folder ******************* 12:59:13: Volume in drive C has no label. 12:59:13: Volume Serial Number is 1439-A10F 12:59:13: Directory of C:\Users\Mike\Desktop\War\VIDEO_TS 12:59:13: 01/02/2008 12:41 PM <DIR> . 12:59:13: 01/02/2008 12:41 PM <DIR> .. 12:59:13: 01/02/2008 11:39 AM 6,144 VIDEO_TS.BUP 12:59:13: 01/02/2008 11:39 AM 6,144 VIDEO_TS.IFO 12:59:13: 01/02/2008 11:39 AM 67,584 VTS_01_0.BUP 12:59:13: 01/02/2008 11:39 AM 67,584 VTS_01_0.IFO 12:59:13: 01/02/2008 11:34 AM 1,073,739,776 VTS_01_1.VOB 12:59:13: 01/02/2008 11:36 AM 1,073,739,776 VTS_01_2.VOB 12:59:13: 01/02/2008 11:38 AM 1,073,739,776 VTS_01_3.VOB 12:59:13: 01/02/2008 11:39 AM 1,048,422,400 VTS_01_4.VOB 12:59:13: 8 File(s) 4,269,789,184 bytes 12:59:13: 2 Dir(s) 183,233,105,920 bytes free 12:59:13: C:\Users\Mike\Desktop\War\VIDEO_TS> ********************** AV Details ******************* file=C:\Users\Mike\Desktop\War\VIDEO_TS\VTS_01_1.VOB FormatName=mpeg Num_Frames=48897 DurationInSecs=1631 Duration=00:27:11.5 VideoCodec=mpeg2video Width=720 Height=480 Standard=NTSC BitRate=5264 AudioStreamCount=5 Audio1StreamID=[0x80] Audio1SampleRate=0 Audio1Codec=ac3 Audio1BitRate=0 Audio1Channels=0 Audio2StreamID=[0x81] Audio2SampleRate=0 Audio2Codec=ac3 Audio2BitRate=0 Audio2Channels=0 Audio3StreamID=[0x82] Audio3SampleRate=0 Audio3Codec=ac3 Audio3BitRate=0 Audio3Channels=0 Audio4StreamID=[0x83] Audio4SampleRate=0 Audio4Codec=ac3 Audio4BitRate=0 Audio4Channels=0 Audio5StreamID=[0x84] Audio5SampleRate=0 Audio5Codec=ac3 Audio5BitRate=0 Audio5Channels=0 ************************ END ************************ 12:59:13: FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard 12:59:13: configuration: --enable-a52 --enable-gpl --enable-memalign-hack --disable-debug --enable-pthreads 12:59:13: libavutil version: 49.0.0 12:59:13: libavcodec version: 51.4.0 12:59:13: libavformat version: 50.2.1 12:59:13: built on Mar 14 2006 17:24:07, gcc: 3.4.4 (mingw special) 12:59:13: Input #0, mpeg, from 'multi:C:\Users\Mike\Desktop\War\VIDEO_TS\VTS_01_1.VOB*C:\Users\Mike\Desktop\War\VIDEO_TS\VTS_01_2.VOB*C:\Users\Mike\Desktop\War\VIDEO_TS\VTS_01_3.VOB*C:\Users\Mike\Desktop\War\VIDEO_TS\VTS_01_4.VOB*': 12:59:13: Duration: 01:44:28.7, start: 0.280633, bitrate: 5448 kb/s 12:59:13: Stream #0.0[0x1e0], 29.97 fps(r): Video: mpeg2video, yuv420p, 720x480, 9800 kb/s 12:59:13: Stream #0.1[0x80]: Audio: ac3 12:59:13: Stream #0.2[0x81]: Audio: ac3 12:59:13: Stream #0.3[0x82]: Audio: ac3 12:59:13: Stream #0.4[0x83]: Audio: ac3 12:59:13: Stream #0.5[0x84]: Audio: ac3 12:59:13: Assuming NTSC for target. 12:59:13: Output #0, dvd, to 'C:\Users\Mike\Desktop\War\VIDEO_TS\VTS_01.mpg': 12:59:13: Stream #0.0, 29.97 fps(c): Video: mpeg2video, yuv420p, 720x480, q=2-31, 9800 kb/s 12:59:13: Stream #0.1: Audio: ac3 12:59:13: Stream #0.2: Audio: ac3 12:59:13: Stream #0.3: Audio: ac3 12:59:13: Stream #0.4: Audio: ac3 12:59:13: Stream #0.5: Audio: ac3 12:59:13: Stream mapping: 12:59:13: Stream #0.0 -> #0.0 12:59:13: Stream #0.1 -> #0.1 12:59:13: Stream #0.2 -> #0.2 12:59:13: Stream #0.3 -> #0.3 12:59:13: Stream #0.4 -> #0.4 12:59:13: Stream #0.5 -> #0.5 12:59:13: [dvd @ 0069DF34]sample rate not set 12:59:13: Could not write header for output file #0 (incorrect codec parameters ?) ********************** Output Folder ******************* 12:59:13: Volume in drive C has no label. 12:59:13: Volume Serial Number is 1439-A10F 12:59:13: Directory of C:\Users\Mike\Desktop\War\VIDEO_TS 12:59:13: 01/02/2008 12:59 PM <DIR> . 12:59:13: 01/02/2008 12:59 PM <DIR> .. 12:59:13: 01/02/2008 11:39 AM 6,144 VIDEO_TS.BUP 12:59:13: 01/02/2008 11:39 AM 6,144 VIDEO_TS.IFO 12:59:13: 01/02/2008 12:59 PM 0 VTS_01.mpg 12:59:13: 01/02/2008 11:39 AM 67,584 VTS_01_0.BUP 12:59:13: 01/02/2008 11:39 AM 67,584 VTS_01_0.IFO 12:59:13: 01/02/2008 11:34 AM 1,073,739,776 VTS_01_1.VOB 12:59:13: 01/02/2008 11:36 AM 1,073,739,776 VTS_01_2.VOB 12:59:13: 01/02/2008 11:38 AM 1,073,739,776 VTS_01_3.VOB 12:59:13: 01/02/2008 11:39 AM 1,048,422,400 VTS_01_4.VOB 12:59:13: 9 File(s) 4,269,789,184 bytes 12:59:13: 2 Dir(s) 183,233,114,112 bytes free 12:59:13: C:\Users\Mike\Desktop\War\VIDEO_TS> ******************************************************************** ************************ SYSTEM INFORMATION ************************ ******************************************************************** ***************************** VOB2MPG ***************************** Name: VOB2MPG Title: Version: 2.3.0.0 Executable: C:\Program Files\BadgerIT\VOB2MPG\VOB2MPG.exe Executable size: 640 KB Executable size in bytes: 655360 Executable CreationTime: 3/14/2006 9:49:26 PM Executable LastWriteTime: 3/14/2006 9:49:26 PM Executable LastAccessTime: 7/17/2007 2:28:52 PM ****************************** Drives ******************************* DeviceID: C: FileSystem: NTFS Size: 279 GB FreeSpace: 170 GB DeviceID: E: FileSystem: NTFS Size: 3.18 TB FreeSpace: 1.03 TB ******************************************************************** ********************* END OF SYSTEM INFORMATION ******************** ******************************************************************** ********************** Input Folder ******************* 13:00:47: Volume in drive C has no label. 13:00:47: Volume Serial Number is 1439-A10F 13:00:47: Directory of C:\Users\Mike\Desktop\War\VIDEO_TS 13:00:47: 01/02/2008 12:59 PM <DIR> . 13:00:47: 01/02/2008 12:59 PM <DIR> .. 13:00:47: 01/02/2008 11:39 AM 6,144 VIDEO_TS.BUP 13:00:47: 01/02/2008 11:39 AM 6,144 VIDEO_TS.IFO 13:00:47: 01/02/2008 12:59 PM 0 VTS_01.mpg 13:00:47: 01/02/2008 11:39 AM 67,584 VTS_01_0.BUP 13:00:47: 01/02/2008 11:39 AM 67,584 VTS_01_0.IFO 13:00:47: 01/02/2008 11:34 AM 1,073,739,776 VTS_01_1.VOB 13:00:47: 01/02/2008 11:36 AM 1,073,739,776 VTS_01_2.VOB 13:00:47: 01/02/2008 11:38 AM 1,073,739,776 VTS_01_3.VOB 13:00:47: 01/02/2008 11:39 AM 1,048,422,400 VTS_01_4.VOB 13:00:47: 9 File(s) 4,269,789,184 bytes 13:00:47: 2 Dir(s) 183,231,840,256 bytes free 13:00:47: C:\Users\Mike\Desktop\War\VIDEO_TS> ********************** AV Details ******************* file=C:\Users\Mike\Desktop\War\VIDEO_TS\VTS_01_1.VOB FormatName=mpeg Num_Frames=48897 DurationInSecs=1631 Duration=00:27:11.5 VideoCodec=mpeg2video Width=720 Height=480 Standard=NTSC BitRate=5264 AudioStreamCount=5 Audio1StreamID=[0x80] Audio1SampleRate=0 Audio1Codec=ac3 Audio1BitRate=0 Audio1Channels=0 Audio2StreamID=[0x81] Audio2SampleRate=0 Audio2Codec=ac3 Audio2BitRate=0 Audio2Channels=0 Audio3StreamID=[0x82] Audio3SampleRate=0 Audio3Codec=ac3 Audio3BitRate=0 Audio3Channels=0 Audio4StreamID=[0x83] Audio4SampleRate=0 Audio4Codec=ac3 Audio4BitRate=0 Audio4Channels=0 Audio5StreamID=[0x84] Audio5SampleRate=0 Audio5Codec=ac3 Audio5BitRate=0 Audio5Channels=0 ************************ END ************************ 13:00:47: FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard 13:00:47: configuration: --enable-a52 --enable-gpl --enable-memalign-hack --disable-debug --enable-pthreads 13:00:47: libavutil version: 49.0.0 13:00:47: libavcodec version: 51.4.0 13:00:47: libavformat version: 50.2.1 13:00:47: built on Mar 14 2006 17:24:07, gcc: 3.4.4 (mingw special) 13:00:47: Input #0, mpeg, from 'multi:C:\Users\Mike\Desktop\War\VIDEO_TS\VTS_01_1.VOB*C:\Users\Mike\Desktop\War\VIDEO_TS\VTS_01_2.VOB*C:\Users\Mike\Desktop\War\VIDEO_TS\VTS_01_3.VOB*C:\Users\Mike\Desktop\War\VIDEO_TS\VTS_01_4.VOB*': 13:00:47: Duration: 01:44:28.7, start: 0.280633, bitrate: 5448 kb/s 13:00:47: Stream #0.0[0x1e0], 29.97 fps(r): Video: mpeg2video, yuv420p, 720x480, 9800 kb/s 13:00:47: Stream #0.1[0x80]: Audio: ac3 13:00:47: Stream #0.2[0x81]: Audio: ac3 13:00:47: Stream #0.3[0x82]: Audio: ac3 13:00:47: Stream #0.4[0x83]: Audio: ac3 13:00:47: Stream #0.5[0x84]: Audio: ac3 13:00:47: Assuming NTSC for target. 13:00:47: Output #0, dvd, to 'C:\Users\Mike\Desktop\War\VIDEO_TS\VTS_01.mpg': 13:00:47: Stream #0.0, 29.97 fps(c): Video: mpeg2video, yuv420p, 720x480, q=2-31, 9800 kb/s 13:00:47: Stream #0.1: Audio: ac3 13:00:47: Stream #0.2: Audio: ac3 13:00:47: Stream #0.3: Audio: ac3 13:00:47: Stream #0.4: Audio: ac3 13:00:47: Stream #0.5: Audio: ac3 13:00:47: Stream mapping: 13:00:47: Stream #0.0 -> #0.0 13:00:47: Stream #0.1 -> #0.1 13:00:47: Stream #0.2 -> #0.2 13:00:47: Stream #0.3 -> #0.3 13:00:47: Stream #0.4 -> #0.4 13:00:47: Stream #0.5 -> #0.5 13:00:47: [dvd @ 0069DF34]sample rate not set 13:00:47: Could not write header for output file #0 (incorrect codec parameters ?) ********************** Output Folder ******************* 13:00:47: Volume in drive C has no label. 13:00:47: Volume Serial Number is 1439-A10F 13:00:47: Directory of C:\Users\Mike\Desktop\War\VIDEO_TS 13:00:47: 01/02/2008 12:59 PM <DIR> . 13:00:47: 01/02/2008 12:59 PM <DIR> .. 13:00:47: 01/02/2008 11:39 AM 6,144 VIDEO_TS.BUP 13:00:47: 01/02/2008 11:39 AM 6,144 VIDEO_TS.IFO 13:00:47: 01/02/2008 01:00 PM 0 VTS_01.mpg 13:00:47: 01/02/2008 11:39 AM 67,584 VTS_01_0.BUP 13:00:47: 01/02/2008 11:39 AM 67,584 VTS_01_0.IFO 13:00:47: 01/02/2008 11:34 AM 1,073,739,776 VTS_01_1.VOB 13:00:47: 01/02/2008 11:36 AM 1,073,739,776 VTS_01_2.VOB 13:00:47: 01/02/2008 11:38 AM 1,073,739,776 VTS_01_3.VOB 13:00:47: 01/02/2008 11:39 AM 1,048,422,400 VTS_01_4.VOB 13:00:47: 9 File(s) 4,269,789,184 bytes 13:00:47: 2 Dir(s) 183,231,832,064 bytes free 13:00:47: C:\Users\Mike\Desktop\War\VIDEO_TS>
It is because the program can't deduce the bitrate of the audio streams. Drop me an email and i will send you an version where this shouldn't matter.
CB, I didn't get that version.
Can you email to @yahoo.com, then delete my email from this post ?
Thanks -
Email sent.
Hey chris Great work btw on VOB2MPEG 2.3-2.5 works really well but i have one question for you.
When i take VOB2MPEG to create mpegs from my vob sets it puts them into a file that works great with my buffalo media extender but when i try to play them back on my computer using Windows Media Player 11 or even Winamp i have no sound. I can get sound over the media server on the network that goes to my tv but i find it strange i can't get sound when playing them straight on the computer.
Im sure theres some audio codec or something i have to download or maybe something i have to enable to get it to work because i have gotten it once before to play with sound through both windows media player and winamp, but im not really sure what it is.
Do you know what audio type vob2mpeg uses so i can download this format support for my media players? Or does vob2mpeg even matter in this case and the real problem is my ripping method?
I currently use DVD Decrypter to rip the movies to VOB and i use default settings on that software but i use IFO mode and use stream Processing. I always just pull the main movie with only 0x80 - Video - 720X480 NTSC and for audio i just select 0x80 - Audio - AC3 / 2ch or 5ch / English and rip it.
Am i doing something wrong here? Appreciate any help you can give! -
Dwight
- Herm Albright
uatheifofalwayscdc,
AC3Filter should do the trick for you. Right in the Tools section.Have a good one,
neomaine
NEW! VideoHelp.com F@H team 166011!
http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=166011
Folding@Home FAQ and download: http://folding.stanford.edu/ -
Hi,
I was amazed at vob2mgp when I found out that I could convert my ripped dvd's to mpeg to play over my Media Center Extender. Unfortunately, though after the first couple of conversions I seem to have run into a problem. Every time that I try to convert a .vob it just tells me "Finished Processing 0 Vobsets". I'm not sure what to do.
I'm using DVD Decrypter to rip the main movie files of a dvd to one .vob file and then Vob2mgp to convert the .vob to a .mpg. Like I said, it worked flawlessly the first couple of times and now every .vob I try to convert gives me the same message. I've tried multiple movies and it's the same for any dvd I try now, so it must be something that I'm doing differently than before but I can't figure out what. DVD Decrypter is creating a video_ts folder and the naming convention of the .vob is correct, so I don't know what's going on.
Any help is greatly appreciated! -
Tried converting to a different drive and that didn't help
Here's the log file:
Title:
Version: 2.5.0.0
Executable size: 460 KB
Executable size in bytes: 471040
Executable CreationTime: 1/1/2000 12:00:00 AM
Executable LastWriteTime: 1/1/2000 12:00:00 AM
Executable LastAccessTime: 1/1/2000 12:00:00 AM
DeviceID: C:
FileSystem: NTFS
FreeSpace: 15.1 GB
DeviceID: D:
FileSystem: NTFS
FreeSpace: 382 GB
13:14:32: Volume in drive D is DATA
13:14:32: Volume Serial Number is 841A-2677
13:14:32: Directory of D:\shares\Movies\SIMPSONS_PS\VIDEO_TS
13:14:32: 01/23/2008 09:21 AM <DIR> .
13:14:32: 01/23/2008 09:21 AM <DIR> ..
13:14:32: 01/23/2008 09:21 AM 96,256 VTS_02_0.IFO
13:14:32: 01/23/2008 09:32 AM 6,175,244,288 VTS_02_1.VOB
13:14:32: 2 File(s) 6,175,340,544 bytes
13:14:32: 2 Dir(s) 410,449,055,744 bytes free
13:14:32: D:\shares\Movies\SIMPSONS_PS\VIDEO_TS>
13:14:34: Volume in drive D is DATA
13:14:34: Volume Serial Number is 841A-2677
13:14:34: Directory of D:\shares\Movies\SIMPSONS_PS\VIDEO_TS
13:14:34: 01/23/2008 09:21 AM <DIR> .
13:14:34: 01/23/2008 09:21 AM <DIR> ..
13:14:34: 01/23/2008 09:21 AM 96,256 VTS_02_0.IFO
13:14:34: 01/23/2008 09:32 AM 6,175,244,288 VTS_02_1.VOB
13:14:34: 2 File(s) 6,175,340,544 bytes
13:14:34: 2 Dir(s) 410,449,055,744 bytes free
13:14:34: D:\shares\Movies\SIMPSONS_PS\VIDEO_TS> -
I've had similar problems with vob2mpg.
I've found 2 ways around it:
Either try running vob2mpg again immediately after you get the message or
Leave vob2mpg loaded up for about 30secs before starting the conversion
Using above methods I have no probs converting from one HDD to another one.
Fl -
Thanks for the help, but I seemed to have stumbled upon a solution...I wanted to try DVDFab HD Decrypter but during the installation it said that it is not compatible with DVD4FREE, which I was using to remove any protection. So after uninstalling DVD4FREE I ran DVDFab and then VOB2MPG and everything worked great. I'm assuming that there was a conflict with DVD4FREE and VOB2MPG. Go figure! I've ripped and converted about 20 DVD's in a row now with not a single problem!
By the way, does anyone know if it's possible to convert a 4:3 to 16:9 and if so which program they use? Do you convert the .vob or the .mpg?
Thanks for all your help! -
Crissyboy,
Looks like this is the general dumping ground for VOB2MPG, so here goes...
Like others, VOB2MPG worked great on the first couple of movies, perfect tool. Then all of a sudden I received the same symptoms: Finished doing 0 VOBs, errors here and there, gets stuck. Though I'll try a couple of suggestions from previous posters (Wait 30 seconds, rerun immediately - only works sometimes) here's a log from the last one I ran, but unsuccesful:
Title:
Version: 2.5.0.0
Executable: E:\Vidsoft\VOB2MPG\VOB2MPG.exe
DeviceID: C:
FileSystem: NTFS
FreeSpace: 42.9 GB
DeviceID: E:
FileSystem: NTFS
FreeSpace: 100 GB
DeviceID: F:
FileSystem: NTFS
FreeSpace: 227 GB
07:47:14: Volume in drive F is Multimedia
07:47:14: Volume Serial Number is CE29-0F5D
07:47:14: Directory of F:\Temp\VIDEO_TS
07:47:14: 01/28/2008 07:47 AM <DIR> .
07:47:14: 01/28/2008 07:47 AM <DIR> ..
07:47:14: 01/25/2008 11:12 PM 129,024 VTS_01_0.IFO
07:47:14: 01/25/2008 11:23 PM 5,565,978,624 VTS_01_01.VOB
07:47:14: 01/25/2008 11:23 PM 521 VTS_01_PGC_01 - Stream Information.txt
07:47:14: 3 File(s) 5,566,108,169 bytes
07:47:14: 2 Dir(s) 244,035,399,680 bytes free
07:47:14: Not enough storage is available to process this command.
07:47:14: F:\Temp\VIDEO_TS>
07:47:15: Volume in drive E has no label.
07:47:15: Directory of E:\TEMP\video_temp
07:47:15: 01/25/2008 07:06 AM <DIR> .
07:47:15: 01/25/2008 07:06 AM <DIR> ..
07:47:15: 0 File(s) 0 bytes
07:47:15: 2 Dir(s) 107,993,657,344 bytes free
07:47:15: Not enough storage is available to process this command.
07:47:15: E:\TEMP\video_temp>
Its complaining about not enough storage, but obviously, there's more than enough to go around...for now. The only thing I tried on this one was to use DVDDecrpter in stream mode instead of file mode.Have a good one,
neomaine
Just a guess - but i think it is having an issue with "VTS_01_PGC_01 - Stream Information.txt" Can you rename it to "PGC_01 - Stream Information.txt"?
I'll try that tonight...
Have a good one,
neomaine
ChrissyBoy,
Thanks, that did the trick! I'm humming along once again. Now, just to figure out how to set the in/out resolution so everybody doesn't look too skinny... 16:9 is ok, just need 2:35... But that a VirtualDub question...
Appreciate the help. And, keep up the good work on the tool!Have a good one,
neomaine
chrissboy,
i never succeeded with vob2mpg. whenever i tried i failed i get the results as=the same as suggested bny tropicub on nov 27. zero files converted.kindly suggest . -
i always failed to get the result with vob2mpg. it gives a message as suggested by tropicub in his post on nov 27. zero files converted. help plz. thanks.
Post your log.
Dwight
- Herm Albright
Hi there, new poster here, hoping that someone can help...
Like others, I'm getting the same problem that when I run vob2mpg, it converts 0 files in 0 seconds. I've tried the suggestions about running it again immediately after, and leaving it for a while before running, but to no avail
. I've even tried several different vob sets in case there was something wrong with one of them, but still no joy. Here's a copy of the log file:
The disc was ripped using DVDDecrypter, I think in IFO mode, extracting the main movie only.Code:******************************************************************** ************************ SYSTEM INFORMATION ************************ ******************************************************************** ***************************** VOB2MPG ***************************** Name: VOB2MPG Title: Version: 2.5.0.0 Executable: C:\Program Files\BadgerIT\VOB2MPG\VOB2MPG.exe Executable size: 460 KB Executable size in bytes: 471040 Executable CreationTime: 01/01/2000 00:00:00 Executable LastWriteTime: 01/01/2000 00:00:00 Executable LastAccessTime: 01/01/2000 00:00:00 ****************************** Drives ******************************* DeviceID: C: FileSystem: NTFS Size: 149 GB FreeSpace: 121 GB DeviceID: E: FileSystem: NTFS Size: 41.9 GB FreeSpace: 41.8 GB ******************************************************************** ********************* END OF SYSTEM INFORMATION ******************** ******************************************************************** ********************** Input Folder ******************* 11:51:11: Volume in drive C has no label. 11:51:11: Volume Serial Number is 0000-0000 11:51:11: Directory of C:\APPLESEED_DISC_1\VIDEO_TS 11:51:11: 02/03/2008 11:44 <DIR> . 11:51:11: 02/03/2008 11:44 <DIR> .. 11:51:11: 02/03/2008 11:36 94,208 VTS_03_0.IFO 11:51:11: 02/03/2008 11:38 1,073,379,328 VTS_03_1.VOB 11:51:11: 02/03/2008 11:39 1,073,534,976 VTS_03_2.VOB 11:51:11: 02/03/2008 11:40 1,073,498,112 VTS_03_3.VOB 11:51:11: 02/03/2008 11:42 1,073,698,816 VTS_03_4.VOB 11:51:11: 02/03/2008 11:43 1,073,737,728 VTS_03_5.VOB 11:51:11: 02/03/2008 11:44 1,073,727,488 VTS_03_6.VOB 11:51:11: 02/03/2008 11:45 349,325,312 VTS_03_7.VOB 11:51:11: 8 File(s) 6,790,995,968 bytes 11:51:11: 2 Dir(s) 130,930,429,952 bytes free 11:51:11: C:\APPLESEED_DISC_1\VIDEO_TS> ********************** AV Details ******************* ************************ END ************************ ********************** Output Folder ******************* 11:51:11: Volume in drive E has no label. 11:51:11: Volume Serial Number is 6044-84F1 11:51:11: Directory of E:\Output 11:51:11: 02/03/2008 11:49 <DIR> . 11:51:11: 02/03/2008 11:49 <DIR> .. 11:51:11: 0 File(s) 0 bytes 11:51:11: 2 Dir(s) 44,939,636,736 bytes free 11:51:11: E:\Output>
Any ideas?
Thanks,
Dave.
vob2mpg
By peebee44 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 26th Dec 2011, 16:02 -
VOB2MPG not working
By les972 in forum Newbie / General discussionsReplies: 6Last Post: 19th May 2010, 20:05 -
Unable to install VOB2MPG or VOB2MPG PRO
By tooc in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 28th Mar 2010, 01:53 -
Where to get vob2mpg v2
By freq in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 15th Nov 2009, 12:47 -
vob2mpg problem
By branjk in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 27th Oct 2009, 03:14
