    Washington, D.C.
    Having been mainly a lurker and reader and not wanting to wait for my question to be discussed, I thought I'd post a question similiar to the subject topic that happened in a different thread.
    I think, I understand the process of mass producing single layer discs. But then maybe not, I believe that I have read here that they are mainly pressed. Now is this the same type of process for mass producing d/l disks or do companies use large banks of recorders to burn d/l discs in a 24x7 operation?
    Lastly, is there a way or tool to use that will tell whether a d/l is +/-. If there is such a thing as - d/l. I am only asking about the commerically produced versions and not the blank ones you and I can purchase over the counter.
    May 2004
    All commercial DVDs (single and dual layer) are pressed, not burned, and they all read as DVD-ROM.
    Washington, D.C.
    Gen-An,
    Thanks. Still a bit confused. If dual layers are pressed, then I presume they just glue [ } the layers together and cover them both with some protective covering.?
    Also, then in that case they are neither + or - ?
