  1. i have a dual boot and i would like to capture and author dvds on a shared partition.
    what is the best format?
    fat32 is what i havenow which has a 4 gig lmit.
    ntfs cant be written to in linux.
    im open to any solution?
    check out the afrobros at
    www.afrobrothers.org
  2. You want to know what the best is for linux? I have no Clue.
    Besides that I would go with NTFS.
  3. NTFS is what you need for working with large files. 30 minutes of DV can take 6-7 GB before compressing to MPEG2 DVD. How about MAC, isn't OS10 linux based? They can't have a 4GB limit for file sizes!?
  4. linux is great, but for servers and netwroking.
    you should use ntfs if you want no limit.
  5. yeah i guess what i am after is maybe a mac format or somting that accessable to both. i know ntfs will work for windows but i was hoping there was a format both:
    read/writable from linux
    can handle very large files
    if this format does not exist then ill go with ntfs as suggested.
