I purchased the latest Nero 6 and when I try to copy from a DVD-R in my DVDrom to the burner I get a message saying (cannot copy this disc to DVD). The disc isn't copy protected or defective. When I click on disc info it shows a blank source disc. If I put the source disc in the burner and hit copy it works and shows the DVD-R content. The same problem occurs on every computer that has Nero 6 installed. I was using Nero 5.5 and didn't have a problem with this.
Results 1 to 9 of 9
and you have checked your settings to make nero read ur dvd-rom as the source drive?Sounds like you have it setup to read the dvd-rw as the source drive to me.
Yes. Everything is setup right. Nero 6 just can't read the content on the source disc unless it is in the burner.
Hello,Originally Posted by twinegar
Can you play it in a normal dvd player??? It sounds like it isn't finalized if you can't play it in a dvdrom but the burner will play it.
Welcome to the wonderful world of Nero Digital Rights Management. Take a look at which processes are running, if you see NeroCheck.exe you have DRM telling you what you can and cannot do.
I tried to copy my Nero CD; while it was verifying the copy it gave an error (nero.exe is different). I did a compare on the original nero.exe and copy and the data had changed at 2 different addresses. It didn't do that on other copies I'd made. -
I really dont like Nero.
I have a special Plextor edition (to go with my Plextor drive)
I only use it to make images (which i then burn with Decrypter)
Have you tried ripping the contents of the source disc to a file on your HD, and then getting Nero to use the HD files as source? -
Earlier versions of Nero 6 had this problem. Update to latest version and all will be well
...or make an image first, then burn image, using your writer only. Disc to disc copy is never a good idea (in reality) anyway.
/Mats
store bought dvd won't play in laptop or pc, can't copy
By ghola in forum DVD RippingReplies: 11Last Post: 8th Mar 2012, 17:17 -
DVD player's copy protection won't even let me rip home movies.
By Brian. in forum DVD & Blu-ray RecordersReplies: 12Last Post: 27th Mar 2011, 16:12 -
Nero freezes when trying copy dvd
By Shotobits in forum Newbie / General discussionsReplies: 3Last Post: 1st Nov 2009, 04:30 -
NERO Vision Won't Produce DVD's
By Ensign in forum DVD RippingReplies: 11Last Post: 29th Sep 2009, 11:43 -
Nero won't burn video DVD
By solo_voyager in forum Newbie / General discussionsReplies: 3Last Post: 13th Nov 2007, 22:06
